Interested in at least 3 if there’s AA support. I personally don’t care that much about it being Anduril, but the hold-to-off has to go.
The only thing I hate about the current SP10S is the interface.
Interested in one.
Interested.
Can you guys leave just one flashlight for us simple minded folks ?
Since joining this forum I have acquired a multitude of flashlights that require me to read the instructions before each use .
I would be elated if Sofirn would make two versions of each flashlight . One with a simple low , medium , high and off . And the other with your strobe , firefly , romantic , disco ball, SOS , slow SOS , medium SOS , strobe , slow strobe , fast strobe and anti aircraft modes.
No.
I figured as much
Theres plenty of simple flashlights already.
SD02, SD05, SD01. Magbutton or magring, simple.
Great idea
Interested, please add a moonlight mode and smooth ramping. Also recess the switch so it doesn’t stick out as much.
This Light is actually on my grail list. Simply, an AA light with anduril.
I bought one and liked it so much I bought a second.
Is progress still actually continuing on this light? Just wondering
Also Smooth angles of body and smooth knurling instead of pineapple…and no more sharp edge.
I assume this project is not happening, but it would be nice if someone involved would just chime in “cancelled” or “continue to be patient” or “uncertain.”
I think they postponed all AA projects for “next year” or so
Sometimes ya gotta take matters into your own hands. Sure, it’s not a production light but one of my SP10S’s is now running Anduril2 via an adapter board.
Note: for the voltage divider, I accidentally picked a pin on ADC1 instead of ADC0. Rather than hacking Anduril to switch between the two ADC’s (temperature sensor is on ADC0), I just ran an airwire. Not great, but it works.
Nice fix/mod! I love the light but don’t like the interface so maybe I’ll do something similar in the future… I suppose it’s 14500-only now? Or do AA batteries still work? Do you have the files on GitHub so other people can create this too? Maybe you can sell it on Tindy too
EDIT: Can you also maybe slightly increase the board dimensions so you can have a programming header and flash other Anduril versions? Although 2 would be perfect I guess, I mostly just use the battery-check functionality and ramping…
