Lumintop FW21 X9L or Pro?
19 posts / 0 new
Chicken Drumstick
Last seen: 4 weeks 14 hours ago
I don’t have any SBT90 lights. And stumbled across the X9L.
What are peoples thoughts on it, it looks impressive?
How does it compare the triple XHP50 FW21 Pro however? It is a fair bit more money.
Anyone have any side by beam shot comparisons of both?
As well as physical size? They look to have the same tube and head design, just with the X9L having a longer head for the reflector.
How do they compare size wise to something like a Noctigon KR1 or Eagles-Eyes X6? These are about as big I’d EDC.
Thanks.
richbuff
Last seen: 24 min 35 sec ago
Buy both, and then decide  which one you want to give to a friend, and which one you want to keep. The triple small, shallow reflectored 50.2 light is a lot more floody than the single SBT90.2 light, which in turn is a lot more throwey.
Wide and short beam, or skinny and long beam. That is the question.
Because I like big lights, my flashlightical views lean heavily toward both the extreme bright and the extreme heft.
1313
Last seen: 5 hours 31 min ago
SBT90 is great. Tons of output and throw. Can’t compare to the pro, but here’s mine compared to a KR1.
I prefer the button on the KR1 but everything else I prefer about the X9L.
andreas0401
andreas0401's picture
Last seen: 1 day 18 hours ago
Here is a comparison of the X9L and the FW21Pro
Chicken Drumstick
Thanks both. Very helpful Smile
MascaratumB
MascaratumB's picture
Last seen: 42 min 13 sec ago
Your videos are always spot on to compare beamshots !!!
Great work!
Notmyrealname
Last seen: 43 min 57 sec ago
MascaratumB wrote:
Your videos are always spot on to compare beamshots !!! Great work!
I’ll second that, I always find your videos interesting and useful when considering a light.
I have the FW21 pro and have been considering the X9l for a while, the price and Xmas coming has delayed me pushing the button. They are very different beams. FW21 pro is very floody and although I’ve seen throw claims of 325m, I don’t think so even with all those lumens. According to the reviews I’ve seen, X9L has great throw and enough spill to be useful, (but not ideal) at closer range. I really want It.
If I could do it over and had to choose between the 2 I’d likely choose the X9L even with the price difference. My personal preference, yours may differ.
I feel sorry for people who don't have a hobby or interest to escape to.
mortuus
mortuus's picture
Last seen: 6 hours 14 min ago
i only have the fw21 pro. ithink its a great light, dont have the other i think its too expensive imo and im not sure i need such a led i have plenty of throwers already i think more use of a more floody beam or something..
...where Frugal meets with Flashlight!
              つ ◕_◕ ༽つ
Chicken Drumstick
Does anyone know how easy these are to accidentally activate?
I’m having real issues with my Noctigon KR1. When I carry it clipped to my jeans pocket, it keeps turning on. I think when I sit or get in a car, the button gets gently pushed by my clothing. Never had this issue on other tail clicky lights. But I’d hate to spend out on the FW21 to find the same issue.
Katherine Alicia
Katherine Alicia's picture
IMO, the FW21 Pro is Really easy to trigger, you`ll need to tail-cap lock out for EDC. it`s a flush mounted flat metal tail switch that`s about as easy to press as the keys on your keyboard and just as quiet.
Hikelite
Last seen: 2 weeks 4 days ago
I’m having real issues with my Noctigon KR1. When I carry it clipped to my jeans pocket, it keeps turning on. I think when I sit or get in a car,* the button gets gently pushed by my clothing*. Never had this issue on other tail clicky lights. But I’d hate to spend out on the FW21 to find the same issue.
It might only be yours or a certain batch, my KR4 just does not turn on like that.
Artiet59
Last seen: 4 hours 41 min ago
I have both and love both, but if I only hd to have one of defintely take the X9L, because of versaitity and it’s impressiveness. Like I said I Love both but the pro could be replaced with say the mf01 mini, in terms of output. I de domed my pro and I like that more, but it was fine before too. The X9L is just an impressive little light. Might be too much power for a little light but I don’t own anything like it and I have to imagine there’s not anything too much like it. Maybe the amutorch xt45, which also is a little less expensive, but I don’t own that to compare.. anyway you would be happy with both.
Chicken Drumstick
That might be the case I agree it is a possibility. And I only have a sample of one to look at.
But there doesn’t seem anything obviously wrong with it. The switch has very short travel and is only just recessed enough to allow stable tailstanding. Although when tailstanding you can push down a very small amount and feel the switch move, but not enough to to do anything.
However, it does confirm the switch is not suitably recessed from a design point of view. I believe it is this combined with the short travel that are the issue.
I have approx 30 other lights I EDC on a regular basis. None of them with mechanical tail switches have ever caused an issue in almost a decade of carry.
I don’t have many electronic tail switch lights. The only other one is my Maglite XL200. The switch feels similar weight/effort to depress (maybe every so slightly heavier on the Mag, but really close). The Mags switch is more domed. So the edges are recessed further, but the dome of the switch isn’t.
The KR1 switch does have a small amount of wobble movement if you press it on an edge.
Very very occasionally will the Mag turn on by accident. Maybe only once during an entire period of carry. The KR1 I’ve attempted to EDC 5 times and each time within less than an hour it has turned on. And sadly as a double click will take to max or turbo if a click then a double click. That seems the most frequent way it ends up being on in my pocket!!!
It is such a shame. As it is such an awesome light otherwise. But with it turning on like this it is almost junk and worthless. As it is unable to fulfil the primary role for buying it. Sad
I did have a look at trying to access the switch, but it is either done up super tight or glues. Either way I was unable to unscrew the retaining ring and would risk damage trying any further.
A lowered switch or raised edge around the switch might well solve this. But I dount there really is much I can do personally to “fix” the design flaw.
I would be mortified however to buy something like the 9XL, which is pretty pricey to me. Only to find out it too was useless as an EDC light.
1313
^ I had to do the o-ring trick (replace plastic nub in the button with a small o-ring) on my X9L before I was comfortable carrying it in a jacket pocket. No issues now.
Artiet59
^ My KR4, KR1, FW3a, Pro 21, all Pro X9L accidentally turn on when i sit in my car and they are clipped in my pocket. Though, my FW3a does not as bad because of deep carry clip and i did the O-ring button mod – but i hate how the switch feels now and am just too lazy to take it apart again to switch it back. All of my aforementioned light turns on because my seatbelt holder hits them square on, they are just in the right spot bc none of them don’t have deep carry clips. KR4 and KR1 deep clips on the way though.
I have grown accustomed to just unscrewing the head on all 5 lights when they are in my pocket and i am either getting into the car or working with a tool belt. actually i usually just have the head untwisted a 1/4 turn while carrying all of them and now it is second nature just to twist it before turning the light on. Really is not as much of a bother as it sounds. That o-ring mod just takes the life out of a really nice feeling tail switch IMO.
Chicken Drumstick
Where can I get a deep carry clip for the KR1? Thanks.
1313
I agree. Im not a huge fan of it but I’ve found it necessary if I want to carry it without locking it out. I like the raised switch ring on the D4V2 and wish the X9L could have something similar.
Artiet59
Yea something raised on the tail switch of these multiple tail switch lights would be great. Or even making the tail switch button much more recessed would be great.
mortuus
mortuus's picture
Yes if u dont do electronical lockout which i recommend its kinda unsafe have such a light in your pocket or whatever.
              つ ◕_◕ ༽つ
