Reminds me of the Olight I1R2, except this has high CRI and uses stainless steel instead of the usual black-anodized aluminum.
I wonder if they used USB-C on it for the charging? Can’t find any information on that. Hopefully the head is also captive!
In any case, this looks like a neat keychain light! It’s nice to see Sofirn branching out more.
I took delivery of two of these today. Initial impressions very good. The emitter is immediately impressive CRI compared to all the CREE XP-G2 10180s, and the tint is slightly warmer than my recent Emisar D4V2 CuZn SST20 4KK. It's a solid SS build (26.7g on my scale w/battery) with a noticeable heft compared to the Olight I1r2 (16.9g) and slightly better grip. We are getting closer to the perfect keychain light... Let's see this in Ti or Aluminum next with USB C and some nicely aggressive knurling?
Thanks abbazaba for this very first report on this light.
Since a 10180 battery weighs almost nothing, the advertised 26g in the description was not a typo. So the walls must be very thick, hence the slightly greater diameter (14.2mm vs 13mm for an Astrolux M01) and almost double the weight.
Looking forward to an Al version too.
abbazaba, can you please comment on the thread machining? My Astrolux M01 is almost unusable because of too much play in the threads, which makes the head very wobbly.
Also, can the battery be accessed (and therefore replaced)? The non-replaceable, and even worse non-accessible battery on the Olight IR2 EOS made me return it, because you can't even measure its voltage to monitor the charge status.
Oh nice, a replaceable battery! That’s a good advantage over the I1R2. And the size is even comparable!
I guess the head isn’t captive though, so you have to be careful to keep it nearby when you’re charging this thing.
330 lumens from a 10180 seems high. On a capacity basis compared to high drain cells, that’s like getting 10,000 lumens from an 18650 light (2600 mAh vs. 80 mAh).
I’ll be curious to see what anyone might measure. To be honest, I think 150 lumens would be quite good for a 10180 light.
Ordered a couple of these Sofirn SC01 to check out…
They come in a nice little blackbox.
Upon receiving them, I tested the flashlight, but there is no light at all.
I then tried to charge the flashlight, but then the green indicator just lights up.
I previously thought the battery is built-in / non-removable, but found that the tailcap is removable.
That’s when I noticed that both SC01 units DO NOT include 10180 batteries.
That makes these flashlights unusable as I do not have a way of purchasing 10180 batteries…
Disappointed that the 10180 batteries are NOT included in the SC01, making these flashlights useless…
Darn, that’s quite the disappointing discovery! Did you accidentally choose the option for “no battery” on AliExpress? (I guess it’s the first/default option, so that’d be easy to do accidentally.)
Hopefully Sofirn will make these available on their standalone store, since they do sell batteries for pretty reasonable prices there.
I recommend you buy two, because these may arrive dead. And do take care of them: no over discharge, they are not protected. I use to charge them when they get under 3.7V.
The problem is: most foreign stores DO NOT SHIP batteries to my country. I cannot find any 10180 battery local store, and I have not found any foreign store that ship 10180 batteries at economical price to my country.
If they do ship, they probably charge a very high price (like $20 or more) (will likely be more expensive that buying another SC01).
And, I did mention to “include batteries” in my order, since I know I cannot order 10180 batteries elsewhere.
