I really like the green ano, a nice deep olive. Here illuminated with 4500K 9080 219b :
Sorry, had to take my glasses off to see clearly - what I received as follows :
2 - orange - no potting does have o ring
1 - green - potted
1 - brown - no potting does have o ring
1 - blue - no potting does have o ring
1 red 670nm RED - potted
Is it just a simple 5mm inner diameter o-ring that would be needed after removing the potting material?
EDIT: Nevermind… I think they all have o-rings… brain is just a little foggy at the moment.
shirnask, thanks for the potting and O ring info, very helpful
Im satisfied that it appears All C01 have O rings around the 5mm LED
Potting summary:
potted C01 colors:
black
green
red
NOT potted C01 colors:
orange
brown
blue
Oh, weird that they potted some of them but not the others!
Wonder if the factory didn’t get the memo when they manufactured certain colours.
maybe
or, I speculate
factory staff says: Boss, were running out of potting compound.
Boss says: those guys on BLF are really cheap… Im not buying another barrel of potting compound, too expensive, and too much labor. Finish the rest without potting…
factory staff says: Yes Boss
and
factory staff says: Boss, the red 5mm LED has beam artifacts
Boss says: those guys on BLF are really cheap… Im not buying another bag of LEDs, too expensive, too much labor. Finish the rest with the LEDs you have.
factory staff says: Yes Boss!
One more here to confirm the above list, my colors are potted the same
Already did a first mod, one I was having in mind since the desire for a host version. Simplest travel nightlight ever for my son, for which application 7 lumen is too bright.
I used a 2300K 95 CRI led from rngwn (I cherrypicked one that was duv –0.0017) , which is shorter than the stock led so probably a littlebit light is lost in the head (looks like not much). And I changed the 220 (22 Ohm) resistor for a 221 (220 Ohm) resistor. The battery current went down from 70mA to 10mA (good for runtime) and the light went down from 7 lumen to 0.7 lumen (some of that reduction is caused by going from a 3400K led to a 2300K led). At 10mA, a AAA alkaline has about 2700mAh so that should be about 270 hours runtime (as opposed to about 40 hours for the stock light).
Genius move by Sofirn in my opinion to pot some of the lights - what a fun surprise. I had ordered one potted color and one not-potted color already (plus two C01S).
Just ordered two more not-potted and planning to adjust output like djozz. What size resistor is used?
Maybe I missed it but….
Are the C01S’s potted?
All colors?
None of the C01S’s are potted, but some of the new C01’s are. (The original C01’s were all potted, though.)
I’m still waiting for mine in the mail to see what I got, haha.
I think the stock resistor was 0402, but I replaced it with a 0603 size one. Had to fiddle a bit with solder iron and tweezers to make both solder ends connect.
I won`t go below 1206, so I admire your work there!
I must admit that while hobbying I have done a lot of this small stuff by hand-soldering so I developed some skills, but it is still easy to get frustrated and fail.
djozz, would a pencil mod be ok for Rangwans high power LEDs? Not sure what the resistance would be.
It’s very hard to control the resistance of a pencil trace. It might work for a digital enable line, but not for this purpose.
Ok, thanks.
For a lower current the resistance must go up, so it starts with removing the stock 220 resistor. Removing a resistor often is the hard part for me, one reason could be that industrial solders may be lead-free and have a high melting temperature. (my method for heating up the resistor is loading the solder tip with a large solder blob and cover the whole resistor with that blob, once the resistor unsolders launch it with something pointy like the tip of your tweezer, or maybe a tooth pick).
If you want to increase the current the resistance must go down, Noctiluco posted a while ago that a complete bypass a bit more that doubles the current (so about 50mA to the led), that is easier, a simple solder blob on top of the resistor could do that, electrically connecting the two sides. Or a bit more subtle is solder an extra resistor on top of the old one. Or you could still go for removing the old resistor and replace it.
Removing it is, as you said, the hard part. I’d try a small copper wire, but 50mA is not so challenging for the 32K-C-EX.
