What do they mean by “Hand Orientation Ambidextrous”?
A and B selection is a bit ambiguous also
Butt for $8.49 I have a pair of L gray b coming (free returns ya know))
I picked up a pair of these, we’ll see how it goes. thanks for the code
I was looking at these myself. Please let us know how you like them. The few negative reviews were about water getting in them.
I got my two lights today. After a bit of futzing around I was able to adjust the panel and light/sensor for my installation, which is inside a carport. Sun comes through a sunlight to charge. I got home late in the day, so the panel didn’t get a lot of light before dark. I eventually figured out the switch is a slider (like me) not a push button, and got it turned on. I did a quick compare side by side, the light puts at least as much light as my LT1 on high. Its plenty bright in my setting. Its advertised at 800 lumens, I believe it.
I did a quick disassemble of the panel to see what sort of battery is in it. Reviews said it was not replaceable. After removing 8 small screws, I found a single 2200mAhr 18650 cell charged to about 3.8V. I measured the current draw, its 1A. The panel housing has an o’ring and a tongue and groove fitting, so I imagine it’s pretty water resistant. I didn’t disassemble the lights, just the panel housing.
If I could have bought one for $13 it would be a screaming deal. I didn’t need two, but I’m happy with the purchase and would definitely do it again. Hope it lasts as long as the one I bought 6 years ago and is still going strong, but is much dimmer.
PocketSammich wrote: I don’t need this, but I want it. Please sign me up.
Nb: that’s for a tupac of WW or CW, but there’s also a colored version (1-per) for 6fitty, too.
I got a few of those that take batteries, for indoors, and they’re pretty nice. Thinking of getting a solar version to put outside and not have to screw with it, just set’n‘forget.
Just because, I had to measure the charge current on the solar charged security light
Charges at 0.25A, so like the manual says, even if its fully depleted a good day of sun will get you mostly charged back up again. And you would have to run it for a couple hours for it to get depleted. If the battery doesn’t go belly up, and it doesn’t leak, then this should last forever. When the cell dies, just pop in another.
Oh, I started to take one of the light housings apart, and one of the screws wouldn’t back out. So I put it back together and noticed two of the screws seem stripped. So this could be a source of the leaks that were reported in the reviews. It looks fine, and I’m guessing it will be fine, but that may be the weak point.
Thrunite TH01 headlamp (35% coupon) and the T1 as seen above (25%) are both about 30 USD right now with the clickable coupon. The Wowtac 16340 versions of these are the h01 and the W1.
The Thrunites offer more capacity (18350 vs 16340), higher output and regulation, longer runtimes with more efficient drivers and XHP50 vs XP G2 emitter, and ramping UI.
I bought a Wowtac as a gift, but for myself I like nice flat regulation so I would choose the Thrunite for myself. You get what you pay for here and I think either the Wowtac or the Thrunite are decent kits for the price.
This was fairly easy to assembly, seems all metal (except maybe the flexible part) and is very intuitive. I figured out how to turn on, up, down, change the color, in about 15 seconds without the manual. Nice light.
I bought one but I'm not sure if it will hold up to 'real work'.
Yeah, this is a 'mini' multi-tool, meant for a keychain. I got it for its cuteness factor, but also because it has an exposed bottle opener and includes tweezers which is not common.
I'm ok with the extra weight for the moment and I'm finding it useful.
Yea, I liked it too but my wife took it before I even got it fully assembled
It’s really good flashlight. I have the same one from different brand, Modoao. https://budgetlightforum.com/node/67514
It’s a thrower with bright center but decent spill as well.
I compared it with Convoy S2+ and it’s brighter than the S2+ so their 1200 lumens claim is not exaggerated.
I don’t have rifle to test how it works mounted on a firearm but works fine for home use.
I don’t have any other thrower. Hopefully, I’ll get C8 or something later to compare.
and here are some $9 cycling gloves to go with the bike light using code 2DN3VSX4:
https://www.amazon.com/dp/B07MHGBCMT?tag=slicinc-20&ascsubtag=7effa7d42c...
48AA not enough?
how about 100?
or 100 AAA?
50/50?
$38-40.
WOOT.
https://electronics.woot.com/offers/energizer-max-alkaline-batteries-100...
gamble on some Solar Christmas (or fairy) Lights for $6.50 with code 5998PYKT:
https://www.amazon.com/dp/B07ZF3GDRR?tag=1sale06-20&linkCode=ogi&th=1&ps...
ThruNite T1 Magnetic Tailcap for $30 using coupon:
https://www.amazon.com/ThruNite-Magnetic-Flashlights-Rechargeable-Flashl...
Wowtac H01 16340 headlamp with batt about 15USD after clickable 20% off coupon plus 10% promo code from zeroair’s review https://zeroair.org/2020/06/17/wowtac-h01-headlamp-review/
15 is about right as it seems to be only half as good as it’s Thrunite counterparts.
Which one is twice as good ? Can you provide a link to the twiceness ?
Twice as good for twice the price seems like a parallel bargain .
Sport-Brella Core Vented SPF 50+ Upright Beach Umbrella (6-Foot) – 15$ (cosmetic defect)
amazon.com/gp/product/B07Q7M6PW5/ref=ppx_yo_dt_b_asin_title_o00_s00
WUBEN C3 Pocket Flashlight Rechargeable 18650 Battery Powered LED Tactical Torch with Type-C Fast Charging 1200 Lumens EDC Light (Classic)
Regular price $26.99, After discount price $12.14.
40% off code: PITFEPGJ
Don’t forget the 15% off clip coupon
Quick access link: https://amzn.to/38EnK7G
Good find! Snagged myself one. Hoping it’s more easy with USB charging in the light (Vs. in the battery like in the C5)
ZappaMan
EDC
FW3A, SST20 4000K || S21A, Crescendo Mtn20DD, LH351D 4000K || SP32A, SST40 5000K
Recent/ongoing Mods:
S2+, TexAven 17mm, LH351D | S21A, Crescendo 20mm, XPL HI 5000K | L2 w/Mtn17DD Zener Guppydrv, XHP-50 | C8+ OP, DD XHP-50 |
SP32A w/SST40 5000K | TIR Upgrades | EagleTac clip | Ultrafire C2 w/6A 20mm & LH351D | S2+, Biscotti, Nichia 219C 2700K |
Reviews:
Sofirn SP31 v2.0 Tactical Flashlight (Cree XPL HI) || Sofirn SD05 Scuba Diving Flashlight || Sofirn SC31 USB Rechargeable (XP-G3) || Sofirn SC31 Pro 5000K
How does it compare against convoy s2+?
Looks like good deal with the battery.
However, coupon expired already.
[/quote] How does it compare against convoy s2+? Looks like good deal with the battery. However, coupon expired already.[/quote]
Still under $18 with code.
EDC
Reviews:
don’t know what to get them for Christmas?
$10 does a Smith & Wesson Self Defense Tactical Penlight…..
https://www.amazon.com/gp/product/B0056DG43I/?ascsubtag=1t5oyve53cu30rr9...
Missed it too
of course I don’t check this thread for one day. I have been looking for another deal on the C3 for my mother.
Don’t have a Convoy S2+ to compare but it’s simple for my mom to use and it charges with her USB-C phone charger. Feels like a solid light.
It looks like there’s a 20% code that still works: WUP2HWU8 https://amzn.to/2J8FY6Z
Streamlight 88850 PolyTac LED Flashlight with Lithium Batteries, Black – 600 Lumens
$20.80
It was in stock but now it says Nov 30th.
https://www.amazon.com/Streamlight-88850-PolyTac-Flashlight-Batteries/dp...
Note: 18650’s will not work in this light
Stanley camping cooking set 10.90
https://www.amazon.com/dp/B005188T90/
My reviews:
Thorfire C8s , Thorfire VG-10 , Sipik SK68 , Duracell 350 , Big L@rry , Mystery AAA
another “stocking-stuffer”? has a pressure switch, too.
DZSF Ultra 1200 Lumens LED $19 with code PTQ3Y8SC:
https://www.amazon.com/dp/B07YBV4H16?tag=1sale06-20&linkCode=ogi&th=1&ps...
Samsung EVO select microsdxc are record low price according to camelcamelcamel
64GB – $8.99
128GB – $15.99
256GB – $24.99
512GB – $64.99
I’m sold!
The marketing on these listings is always a fun read.
What mysterious other purpose can it be used for? That, my friend, rests in your hands…
Hey, try speaking Chinese.
