If you can use turbo for much longer than that, the turbo isn’t high enough IMO!
I can turn it down myself (with the button or with the software) if I want a longer running level of brightness. Turbo is for momentary use…that’s literally the whole point of having a turbo. Like nitrous on a vehicle. Use it too much and it’ll probably blow up, but it’s there for short bursts when you really need it. :sunglasses:
I was happy until it broke - switch doesn’t register clicks. I’ve contacted the company about the issue. They asked me to provide video evidence, which I did and then I got ignored. Not recommended.
Just go buy Emisar/Noctigon from Hank. I’m sure you’ll be more satisfied in the long run.
the same happened with the switch in my pl47. If you remove the rubber of the switch, you will probably find a small, round and thin golden plate that is loose
Just wait a while. Jack is real busy and doesn’t check messages and emails for days or even weeks at a time. I’m guessing he is focused on the new lights right now. But he will surely get back to you.
Jack had over a dozen “defective” lights shipped to me to check. More than half of the lights were fine and I couldn’t reproduce the claimed issues. I suggested to him from then on that he should request customers to show videos of the defect before allowing a return. I’m glad he listened. Business is hard for small businesses when people treat returns like it’s Costco.
Can I remove it with no damage? Will I be able to put it back? Did you fix yours?
6 months have passed since then so it must be something else. Maybe he somehow forgot about me… which is doubtful. I’ve reminded him about myself after a week to no awail.
Should I contact him through his site or on the forum? Can you link me to his profile?
Skv89.thanks to you many times…how can be me so blind…this model has no usb.i almost ordered…cant believe this happens to me…thank youuu…order deleted.uhhh
I’m eagerly awaiting the release of the gen2, hoping for a more throwy optic. And if they can make it brighter that’s always a plus. The gen1 is still one of my favorite lights.
I removed the cover, the cover was not damaged, unfortunately the micro-switch broke down and I do not have enough skills to fix it, pl47 is difficult to repairs
I just received an E07 from BG. 2 minutes later I broke the glass lens.
The glass between the optics and the bezel was rattling so I unscrewed the bezel for a looksee and the glass rolled out and hit the floor tiles - broken.
1) Where can I get a replacement?
2) I see mention of a UCL 35mm x 1.9mm UCL lens but will that fit without mods?
3) Is this it? UCL Lens - Flashlightlens.com - Online Store
4) Is it bezel - oring - glass or bezel - glass - oring?
