New Fireflies T1R Mini Thrower-- Release date 25th Jan
Interested!
Im glad to hear both sides of the above issue, because although i’ve had no problems with Neal, I haven’t ordered form him in awhile (for unrelated reasons) and dont want to take the gamble, i know where Ill be buying my upcoming new FF from…
Sounds extremely interesting, especially the combination of the new CULNM1.TG LED, TIR optics, and a high efficient driver.
I’m still missing a combined buck/boost driver for flat regulation, but a buck/FET is already much better than a simple FET - especially because the Osrams are having a quite low Vf.
May I propose a voltage indicator feature using a RGB LED in the switch? Would allow to constantly read the voltage, while charging, while in use, and also while on standby (Andúril supports this).
I would probably get one depending on price.
Interested!
22430 is an interesting choice. I’ll be happy to see how does it work.
I can see the new lights appear in the shop one by one, highly appreciated!
Do you think the T1R will make it before New Year’s holidays?
Verily, I am interested
Interested, I would also like to see one with the green - KP CSLNM1.F1 - 3030 (1mm²) or the green KP CSLPM1.F1 - 3030 (2mm²)
Appears FF has T9R on website. Is this for presales or available now?
CULPM1 6a cc buck no fet, prices approx $100 to $150 for SBT90
In this size, is there a protected battery available? I would like a couple of these lights to send my friends for gifts.
I have to say, I love the different battery tubes and tritium slots so very well done Fireflies! This model is a good size! Looking forward to it launching.
This is very interesting flashlight. I thought it will use reflector, but it look like Fireflies has release new video of it:
Do anyone know what optics is used? It look like some special TIR optics instead of reflector. Do you know how it compare to reflector? It look like there is aux RGB led under the optics which is probably the reason why alumium reflector is not used.
Specs in OP say: High efficient 3.6 Degree TRI Optics; Up to 138cd/LM
I assume typo: TRI should be TIR. Maybe it's like the E01 optic, but I see the E01 is spec'd at 6 degree TIR.
The head diam of this mini light is wider than the E01: 36 mm vs. 34 mm
I NEED IT!!!
Are you referring to Acebeam E10, which uses the same optic as the Manker MC13? I don’t see an E01 thrower. Specs on the FF mini thrower is superior to that of the E10 and the light looks much smaller. I’ll see how it compares when I get it.
Looks awesome i’m interested
Interested.
Has there been more info on price/availability? Seems there has been no updates.
Based on the info in the op.
1. This needs a deep carry pocket clip option
2. The switch needs to be suitably designed (recessed) to avoid accidental activation when in your pocket
E01: https://www.ff-light.com/index.php?route=product/product&product_id=58, 34 mmm diam head
I’m VERY interested in this. Small TIR thrower with cc driver and aux LEDs? Yes, please!
