And here’s the second mod that was needed, 10 minutes with a common solder iron, this is the easiest host ever.
The led is the bit higher current-capable RWN05-32K-C-EX from rngwn (see link), I measured 3007K, 97.2CRI, R9 97 and duv –0.0034 for this particular led ( , how nice can a tint get?)
The 220 resistor was replaced by a solder blob, the battery current went up to 135mA and the output was better than I thought: 25 lumen on a alkaline and 21 lumen on a old crappy NiMh. A major brightness update over the 7 lumen stock.
About the beam of the mod above. The RWN05-32K-C-EX led has slight tint unevenness over the beam, but what is more obvious is a ringy “hotspot” caused by the reflecting aluminium of the C01. I may lightly sand the led itself at some point to make the tint more even, but the hotspot was smoothed out very effectively by circular sanding the reflector with 180 grit sandpaper. The appearance of the reflector did not change much, but the beam did.
Left sanded, right stock.
I should start with a fresh battery, but the light has been used for around 8 minutes now and I’m at 21 lumen. I will keep it on and see what we’ve got in an hour or so.
I doubt that (but I do not have one to check), the bad beam of the red C01 seems to me not caused by the reflector. I think it is because the light emitting area of the red led is much smaller than a white led because it has no wide phosfor layer. And small light sources need carefully manufactured optics to make a good beam, the top surface of a cheap chinese 5mm led is likely far from optical quality, or even 5mm Nichia leds.
Djozz, thanks for this, this will be a great little backup light for hiking, starts high and keeps it pretty good for 4-6 hours, that is what I was looking for. Much appreciated.
Measured up to 7.5 hours now, time to go to bed. Will have another look tomorrow if there is still light, I assume that just as the unmodded C01 it will drain the battery to completely empty. The runtime chart sofar:
Hmm…no regulation without a sense resistor to regulate. I guess I should have seen that coming.
I assume with something in between, like a 10 ohm resistor, we’d see in the ballpark of 12-14 lumens steady for maybe 2 hours or so, then the long decline.
Yes, no regulation, I already noticed that without resistor it does not light, it is simply is series with the led somewhere I guess (before or after boosting?, no idea how that works really).
I’m not fanatic in constant output, a steady decline is useful, like the incan days, there is not so much that demands steady brightness and a slowly fading light does not leave you with surprises.
Well done. You can’t deny the potting crew did a good job on that one.
BTW I downloaded a copy of the SK68 picture for “recreational use”, I can’t help smiling.
