Hi there!
Okay so I have 2 RGB LED Strips connected with a portable RGB LED Amplifier but I cannot get the red light to work on the second strip. The Blue and Green ones do work flawlessly on the 2nd strip.
Things to note:
- I’ve used 2 power supplies (12V, 2A) - one for the first strip, and another for the LED amplifier.
- I’ve tried with not 1, not 2, but 3 separate amplifiers but the red light on the 2nd strip NEVER works when connected with the Amplifier.
- The Red light on the 2nd strip DOES work when I connect the 2 strips without the amplifier (and yes the brightness does reduce in the 2nd strip).
I’m using the following LED amplifier and the connection diagram is as follows.
Any ideas why this is happening or how can I fix it?
Much appreciated!
