Just received my supbeam, I never got any notification of tracking or payment confirmation, but it arrived in less than a week, thank you for the great deal and I appreciate your business and I wish your future endeavors all be great
Yes, I think the L11 was only available as the L11C - with a reverse clicky tailswitch.
It was my favorite EDC - very slim, decent switch, decent beam profile, good clip, perfect mode spacing, perfect output regulation, and a 219B emitter.
But I mistakenly let it fall from a 30 inch high desk to a laminate floor after a year or two of use. It died. I’m not the only person who has had an L3 Illumination light fail from a relatively small drop. I’m guessing that in head down drops, the battery hammers the driver PCB pretty hard.
I liked it enough, though, that I’m tempted to buy another since it is on closeout, and just plan on being more careful with it.
Just grabbed a couple Spark lights. I got 3 from a previous clearance, modded them all - easy to mod. They are well made but nothing fancy - no square threads for example. I think Spark as a company is long gone.
Just wanted to say Thank You to Jake and the guys at SBFlashlights. The L3 Grab Bag and MC1 Plus charger I ordered were shipped fast and I’m very pleased with everything. The 50% off clearance sale made for some incredible bargains. The MC1 Plus looks to be a quality small unit, and the L3 Grab Bag lights were a very nice variety and included L11Cs, L10Cs, and L10s, with a good mix of Nichia and Cree, 3 and 4 mode, and black, orange, and natural.
I have received my Sparks SL5 and is is malfunctioning and the buttons only work when both are pressed and it only cycles through the modes, the light will not stay on, I have sent several messages to SB over the month about this and previous orders, never getting a response
I am not looking for a refund as all sales are final, but merely a response or a replacement, maybe some assistance with possible troubleshooting, I’m looking into the warranty info, but with sparks being out of business for so long, I don’t I think that is a viable route to take
DOES ANYBODY HAVE ADVISE ON MY NEXT COURSE OF ACTION??? , I APPRECIATE THE COMMUNITY
MAYBE SOMEONE OUT THERE CAN HELP
Have a good week guys TY
Ohh, I think I had the same problems as you describe with both the SL5 and SL6 I received. It was weird behavior with the buttons. There's some sort of issue I think has to do with time on the shelf, maybe oxidation at contact points, not sure.
Anyways, I got both lights working 100% perfect now. All I did was pressed hard down on the buttons (only a couple or few times) and clicked on them many, many times. Eventually the mis-behaving buttons started working. Think with mine the tail buttons would work, and the side ones didn't. But even initially the tail buttons were not working properly. If you searched, these lights data back to ~2011-2012 I believe. I thought I could mod them with driver swaps but doesn't look so doable with these Sparks.
What's really interesting about these lights is they have the inner sleeve and tailcap e-switch, way way long before that design came back again, starting with the FW3A. Just goes to show you old is new, and new is old... Something like that . Pssst: it's a better design than the FW3A, using a spring for the inner tube contact. Extra resistance though but more reliability!
Give it a shot though - try pressing down hard once or twice. Might be scary but it started working better right after that for me on the 1st light, then did the same trick to the 2nd and fixed that one as well.
I've dealt with the SBflashlights guys before and found them very helpful. This kind of sale though is scary, sounds more like a going-out-of-business sale.
Super Appreciated Tom E and AFAustin, I am going to try both methods as soon as a I get a chance today, we will see! Hopefully I can just clean all the contacts again,
The sleeve for the e switch does seem a bit rough and pulls cotton on qtips. Would you suggest maybe lite sanding or does the fact that the light will light up with both buttons pressed rule that out
Thanks again y’all
Michael
I took apart the tube, removed the sleeves, but didn't clean anything. With mine it was the switches, and I didn't do anything with them from the inside. Post your results - hope it helps. Betta these things have been sitting around for 7+ years.
My L10 came, but I had a small issue with it. The head was glued solidly into the body. So much so that when I twisted hard on it the bezel came off the brass heat sink. In order to free the slug from the body I had to get the body hot, and when I did it melted the black isolator ring that sits between the reflector and the LED. The light still appears to work, but I was wondering if you can send me a new isolator ring?
