【convoy】Sample L6 with GT 12V 4A 90CRI LED
4262 posts / 0 new
Funtastic
Funtastic's picture
Last seen: 1 day 17 hours ago
Yokiamy wrote:
Lumens are measured with my Lumen tube calibrated against a Maukka calibration light, measured 1490 Lm at startup.
What is the reading at 30s?
Texas Ace Lumen Tube calibrated with maukka lights
New Zealand store – https://www.piercingthedarkness.co.nz (NZ customers only)
Simon Mao
Simon Mao's picture
Last seen: 10 hours 40 min ago
JordanZHP wrote:
Hi Simon, any update on 3×21700 light? Thank you.
The flashlight hosts are almost completed.
Next, the manufacturer will start to produce 18A drivers. Considering the matching problem, some adjustments may be needed.
Yokiamy
Yokiamy's picture
Last seen: 4 hours 21 min ago
I’ve just measured that for you, it drops 110 Lm after that it’s pretty stable and doesnt drop very hard anymore
WTB: Jetbeam TCR-1 or Sunwayman V10R Ti
Funtastic
Funtastic's picture
That’s higher than what I was able to achieve on 3 of mine.
I got different readings for other set ups too. These are all different chips of the CULPM1
7A – 1313 & 8A – 1318 (same chip)
7A – 1260
6A – 1300
6A – 1200
Just shows how much variation these Osram chips have.
On the datasheet for the 8RF bin, Simon sells, has got a Min 1690 lm and Max 1900 lm at 6A
JaredM
JaredM's picture
Last seen: 3 hours 46 min ago
Matching problem? BTW, I’m very excited about this light!
Sidney Stratton
Sidney Stratton's picture
Last seen: 1 min 46 sec ago
Just dropped in (last couple of pages). 3 × 21700 light picks my curiosity.
Any rendering or some info?
JaredM
JaredM's picture
Likely very similar style to the 4×18a. Though I personally wouldn’t mind a little extra aluminum be left behind in the head at the bottom of the reflector well with deeper fins and a thinner bezel that allows for a larger reflector.
rms
Last seen: 3 weeks 5 days ago
Hello,
please could anyone explain, how does low-voltage protection/warning on S2+ 5000mAh / S21A 6000mAh drivers work?
Is it warning only – starts flashing once voltage decreases to certain level? Or does it also cut off the battery – if so, at what voltage?
Also, how does the driver work? What is the max. current on let’s say 50% load? Does it pull 2500mA continuously? Or “caches” 5000mA then 0 for a while, and so on?
I’ve pulled some ICR18650-26Ds from dead laptop battery (2 out of 9 cells dead), and would like to know, whether I can use them. They are rated at 5200mA max current, but I don’t want to push luck drawing 5A off them. At the same time – they’re not protected, thus my interest in voltage cutoff.
Funtastic
Funtastic's picture
Someone else can chime in on your questions but I wouldn’t use the ICR chemisty, specially old cells. ICR can be dangerous without an added protection circuit.
You’d ideally want to use cells with a current rating of 10A+ for a 5-6A driver current. These flashlights require the highest possible voltage on load, when drawing a high load the voltage will drop and how far that drop is depends on the performance of the cell used. There are other factors but I’ll leave it at that. For a 5A cell I’d advise 3A max load. Get something decent. Note that old used cells have a higher risk depending on how healthy it is. If a cell gets unstable just remember you’re holding a sealed metal tube that has the potential to explode
1stein
1stein's picture
Last seen: 5 days 16 hours ago
cothyhu77 wrote:
Now with a bit of detective work I’m sure the S21B uses 22mm drivers not 20mm, check these images I pulled from AliExpress:
Customer picture of S21B
22mm SST40 driver
20mm SST40
I still want Simon to confirm compatibility with S21B and the new 22mm 8A driver, though, since for one thing the new driver uses a pin contact instead of a spring and there might be other things I haven’t considered.
Just a warning S21B does not go along with 20->22mm adapter from KD. The adapter is too high and you cannot screw the retaining ring. It accepts only genuine 22mm drivers. Until you find lower adapter or you file it down.
Barkuti
Barkuti's picture
Last seen: 1 hour 27 min ago
rms,
First of all can't say how the driver cut-off works (never experienced it yet), but the word says cut-off, which is self-explaining.
Cut-off in drivers is one of those things which overall needs room for improvement. In my opinion it is overall set too high (read my P.S. in #3881 post here).
There's still too much actual ignorance about li-ion cells, and besides positive beliefs in this matter I have some straightforward experience. Like leaving a couple scavenged ICR18650-26C cells straight connected to a white led with thin wires for many days (with no driver - closest config to a direct drive setup, less resistance and faster result). Consider the minimum Vf of a white led is around 2.5V or close. This means a li-ion battery connected to a simple direct drive, linear or buck driver driving a white led just cannot get overdischarged. Back to my experience, after disconnection the cells climbed well above 2.5V, which is to be expected.
Another thing I can narrate is my latest experience with my li-ion converted hair clipper. Powered by two TurdFire IMR14500 700mAh (LoL!) cells in parallel, weeks ago I noticed them going weak and losing charge quickly (very high self-discharge). Since I needed it, while I ordered and waited for new cells I recharged the appliance every few days. At some point I forgot to recharge it for many days, and when I noticed it wouldn't even turn on or barely move without load. And still, I confidently dared to recharge it. Nothing wrong happened (it still works right and today or tomorrow will give the old cells their last run). Why? Because li-ion batteries need time to chemically decompose at low voltages. Can't say how much, but must be quite lenghty. I know what I'm saying because I also dared to recharge a couple of the above mentioned ICR18650-26C cells from 1.7V or around. It was a pack of 6 from an old laptop battery and I recharged and tested them all without problems. At last I raised all cells to ≈3.9V and observed their self-discharge over a few weeks. Two cells lost some voltage, and so I discarded them. I kept the rest.
But well, you are free to believe as you like - and deal with the results or consequences.
P.S.: On a side note, overall low lifespan for these (now old) cells. Sold better binned and improved also under other wraps: Shockli and Vapcell, for example. Heter is their OEM manufacturer.
Mon, 11/23/2020 - 13:58
Deleting a just published post causes the forum thread answer notification to fail. Thus, if you need to change your just published post, edit it. Thanks.
Please avoid fully quoting lenghty posts, namely with nested quotes. Trim quotes down to the essential. Helps with neatness and legibility. Thanks.
Barkuti
Barkuti's picture
1stein wrote:
Just a warning S21B … accepts only genuine 22mm drivers. …
Thanks!
Funtastic
Funtastic's picture
Had 4pcs 30Q discharge to 0v and left like that for 4 days, no hope whatsoever in reviving that low.
That’s quite possibly correct what Barkuti says but it’s a different story if a light has parasitic drain in an e-switch. That’s different altogether though, only a protected cell will stop that issue
Barkuti
Barkuti's picture
Funtastic,
0V for 4 days Sammie 30Qs? Well, you can make a test. Recharge them in some safe place to some not too high voltage, observe their self-discharge over a lenghty amount of time, even properly test their internal resistance. If cells still behave normally they could be used. But this is just because of “science”, in practical terms all of the involved effort is worth way more money than the price of a new pack.
Funtastic
Funtastic's picture
Barkuti wrote:
Funtastic,
I charged them at 300mA but they instantly discharged back to 0v so I binned them. Had a 4×18A driver fault drain them
Lightbringer
Lightbringer's picture
Last seen: 27 min 38 sec ago
Funtastic wrote:
That’s quite possibly correct what Barkuti says but it’s a different story if a light has parasitic drain in an e-switch. That’s different altogether though, only a protected cell will stop slow that issue
Ftfy.
Simon Mao
Simon Mao's picture
I got the accessory sample for lighted switch ,
But there are two shortcomings, the tail is not waterproof, the flashlight loses its inverted function.
id30209
id30209's picture
Last seen: 3 hours 31 min ago
That’s not a problem. I’m sure.
Thx Simon
WTB Titanium 4sevens 2xAA tube
stephenk
stephenk's picture
Last seen: 17 hours 55 min ago
Just received my S2+ with KY CSLNM1.FY Will upload a comparison between a 2700k SST-20, KY CSLNM1.FY, and XP-E2 amber when I get the chance.
Simon Mao
Simon Mao's picture
i get some samples from Getian company.
12V 4A driver for L6 is in design ,too
Tater Tot
Last seen: 9 hours 18 min ago
Very interesting.
Is the input voltage going to be 2S or is one cell supported too?
Di_Joker
Di_Joker's picture
Last seen: 8 hours 8 min ago
Wow, is there a chance to see the Convoys S11 and M3 with this emitter?
By the way, can you make a long back cover for the 21700 batteries for the Convoys S11? 26650 already withdraw from the market, to buy them all the more difficult and expensive.
Sorry for my poor english.
1stein
1stein's picture
This is awesome, chapeau bas Simon!
stephenk
stephenk's picture
Comparison of the S2+ KY CSLNM1.FY
All taken on my phone, with fixed white balance to daylight.
KY CSLNM1.FY (S2+) – note the broad spectrum has some colour rendering
SST-20 2700k (S2+) – high-CRI
XP-E2 Amber (KDLITKER E6) – monochromatic
Overall impressions of the S2+ with KY CSLNM1.FY – “beautiful” golden/orange beam, with some colour rendering. Warmer than the 2700k SST-20, but not as warm as the XP-E2 Amber. 5A driver is completely over the top for this emitter, and it gets too hot within a few minutes even on 35% output, thus I’ll need to use it on 10% or 20% for night photography. This emitter would better suit a 3 or 4*7135 S2+.
Barkuti
Barkuti's picture
stephenk wrote:
… Warmer than the 2700k SST-20, but not as warm as the XP-E2 Amber. 5A driver is completely over the top for this emitter, and it gets too hot within a few minutes even on 35% output, thus I'll need to use it on 10% or 20% for night photography. This emitter would better suit a 3 or 4*7135 S2+.
While I understand there are no 2700K SST-20 tests afaik, the 3000K and 4000K high-CRI tested emitters peaked at 6 and 7A respectively, both with quite high Vf at these currents. So, 5A can be considered fine. With a full battery or close you will be driving the 2700K SST-20 close to maximum performance, but as I say still fine. Concerning the temperature thing, it basically is the same with any other emitter. Tip: you can reduce the amount of dissipated heat by charging your batteries to a slightly lower voltage (3.9 - 4V). This also enhances their lifespan.
30% is 1.5A, should be fine. The drivers also feature temperature protection anyway. If I were to have it, I wouldn't complain at all. Just learn to use it wisely and properly, and enjoy.
stephenk
stephenk's picture
Barkuti wrote:
stephenk wrote:
… Warmer than the 2700k SST-20, but not as warm as the XP-E2 Amber. 5A driver is completely over the top for this emitter, and it gets too hot within a few minutes even on 35% output, thus I’ll need to use it on 10% or 20% for night photography. This emitter would better suit a 3 or 4*7135 S2+.
While I understand there are no 2700K SST-20 tests afaik, the 3000K and 4000K high-CRI tested emitters peaked at 6 and 7A respectively, both with quite high Vf at these currents. So, 5A can be considered fine. With a full battery or close you will be driving the 2700K SST-20 close to maximum performance, but as I say still fine. Concerning the temperature thing, it basically is the same with any other emitter. Tip: you can reduce the amount of dissipated heat by charging your batteries to a slightly lower voltage (3.9 – 4V). This also enhances their lifespan.
30% is 1.5A, should be fine. The drivers also feature temperature protection anyway. If I were to have it, I wouldn’t complain at all. Just learn to use it wisely and properly, and enjoy.
The post was discussing the KY CSLNM1.FY. The mention of the SST-20 was just a comparison.
Also, for my photography, I need constant brightness as otherwise I would have to change the exposure for each photo, thus I need to brightness levels that won’t trigger the temperature control.
Barkuti
Barkuti's picture
stephenk wrote:
The post was discussing the KY CSLNM1.FY. … I need to brightness levels that won't trigger the temperature control.
I rushed a bit with the answer. Smile
The CSLNM1.FY is a phosphor converted emitter, this means it must behave like the CSLNM1.TG standard white flat.
Now I understand your issue, the @#$% aggressive temperature protection. The solution is here: Convoy 17/22 mm SST40 Driver temperature protection removal. It involves removing the onboard surface mount NTC resistor. Once located, push it by one side with a hot soldering iron tip until it launches. Salute once done, LoL!
Pilotboy
Pilotboy's picture
Last seen: 13 hours 18 min ago
Will this work with the Biscotti firmware?
Funtastic
Funtastic's picture
Barkuti wrote:
stephenk wrote:
The post was discussing the KY CSLNM1.FY. … I need to brightness levels that won’t trigger the temperature control.
I just get a nail clipper and cut it, it breaks clean off.
LTC
Last seen: 19 hours 24 min ago
This is great. Hope it it will be available in M21C-U or L21A.
