While I understand there are no 2700K SST-20 tests afaik, the 3000K and 4000K high-CRI tested emitters peaked at 6 and 7A respectively, both with quite high Vf at these currents. So, 5A can be considered fine. With a full battery or close you will be driving the 2700K SST-20 close to maximum performance, but as I say still fine. Concerning the temperature thing, it basically is the same with any other emitter. Tip: you can reduce the amount of dissipated heat by charging your batteries to a slightly lower voltage (3.9 - 4V). This also enhances their lifespan.
30% is 1.5A, should be fine. The drivers also feature temperature protection anyway. If I were to have it, I wouldn't complain at all. Just learn to use it wisely and properly, and enjoy.
The post was discussing the KY CSLNM1.FY. The mention of the SST-20 was just a comparison.
Also, for my photography, I need constant brightness as otherwise I would have to change the exposure for each photo, thus I need to brightness levels that won’t trigger the temperature control.
The CSLNM1.FY is a phosphor converted emitter, this means it must behave like the CSLNM1.TG standard white flat.
Now I understand your issue, the @#$% aggressive temperature protection. The solution is here: Convoy 17/22 mm SST40 Driver temperature protection removal. It involves removing the onboard surface mount NTC resistor. Once located, push it by one side with a hot soldering iron tip until it launches. Salute once done, LoL!
I think more of the issue is that the driver’s current options are overkill for the amount of heat produced by the LED. It’s normal that at 100% there will be a step down, but not useful if 35% also steps down. Thus using a lower power drivers such as the 7135 drivers would have probably been a better choice for this emitter.
You can ask for one with the 7135 driver. I’m not sure what are the current instructions for a custom build due to price differences (if anything the 7135 version probably would be cheaper), but you can message Simon. Or if you need more power than the 7135 driver can provide you can ask for the SST40 ‘ramping’ driver, there are two adjustable modes but the UI IMHO isn’t the best and you can set it too high by mistake. Thermal stepdown is useful for most people, but I see that it may not be desirable for light painters.
I will probably just use it on 20% output most of the time rather than getting another one made with a different driver. However I’ll do some tests on how quickly and at what output the temperature controlled brightness balances. Ramping is also not useful for light painters, stepped brightness levels are more preferable.
Just receive mine today, L21A CULPM1…heheh cant wait to test it tonight
1st impression: dont under estimate of what appeared to be the brown cheap convectional box, bcos inside it, is a built-in-quality flashlight…WOW! I love the deep fins, the cut is what really impress me. Looks very complicated head design, make me stare at it for a while…
Compare head to head with FT03, obviously FT03 now look pretty much basics in design compare to L21A where head look really appealing, the glass glare purplish more than FT03, meaning L21A has a good anti-reflective coating. Although the head of L21A weight more than Ft03(balance), its function is more toward efficient thermal dissipation.
