Just in case anyone had any doubt remaining about whether there is an O-ring around the LED!
In fact, this shows it is better installed that I expected - there is a full groove for the O-ring. On the Sunwayman R01A, it is merely held in place in a shallow counterbore by the flange at the base of the emitter.
Great idea for the dead light, and nice work cleaning it up. I really like cutaways, even when itās a simple item. Thereās even a museum in my area that has an entire tank cut in half like this. I spent probably close to an hour studying it last time I was there.
Also, since I looked it up, hereās the SK68 cutaway post:
I think that someone did that for the Yuji led version, maybe even me :person_facepalming: but it is probably buried in this long thread somewhere, and this Sophia version will not be miles different. Think the same curve as above but starting at 7 lumen, less fast decline and stretching out to over 40 hours.
There is a runtime test of the 2018 Yuji version near the end of this review:
It made it nearly 10 hours of regulated output on a 900mAh NiMH cell. Since it is the same driver, and the forward voltage of the Sophia is very similar to the Yuji, performance of the new batch should be very similar.
With the higher initial voltage of an alkaline and their higher capacity at low loads, it should do a little better with alkaline.
I would plan to do an alkaline runtime test with the ceiling bounce app when I receive mine, but I donāt think I have any fresh alkalines in my house. I use NiMH for all important applications, and for everything else, Iāve found that the battery recycling bin at work almost always has plenty of cells in it that are over 1.5V.
He noticed that I had a new batch of C01ās and he remembered the fun of torturing it 1.5 years ago, so he demanded a fresh test. Who am I to deny anyone a flashlight test? , so there we went, and with him 1.5 years stronger I was not entirely sure. But the C01 (a black and potted one) survived fine again, battered but fully functional.
I`v ordered a couple more of these Sophia leds today, but if my son even Thought of doing anything like that to my lights, I`d whack him so hard not even Google would be able to find him!
Just got a few of the colored C01. I was expecting Desert Tan and green.
I gave some to my friend who is a Vet Doctor, right away he said that both of the lights are almost a perfect color match for a healthy dog poop
Barry, now I am wondering what did your guys mix in the anodizing powder
I got these ones for my C01S from FastTech: https://www.fasttech.com/p/4113703
I noticed that at 90 degrees on a smooth metal surface, the light may slip a bit (though Iām not sure if thatās about how strong they should be.)
