The LH351D dome fits but there is barely any play, in practice since the four LEDs wont be perfectly placed I doubt it will fit. Maybe if the LEDs could be perfectly placed by reflowing with the optics on them, but will it survive the heat ?
Nice! Do you have any tips for reflowing a multi-emitter board like this?
I’m thinking I only want to swap out only the CW SST-20s in my IF25 for LH351Ds…though I feel like mixing beam patterns may not look so good.
I had the same question. I clicked 4 times from on and the light flickers as if something had registered, but it was still stuck in step mode. I couldn’t figure out how to get it to switch to ramped brightness mode. I tried it about 20 times and eventually it went into ramp brightness group. Seems like the timing is VERY VERY picky! I think what I was seeing was the strobe mode flicker on click 3 and then on the 4th click it turned off strobe mode. I’m still not sure how to get it to change between the stepped and ramping brightness groups. The tint control works as advertised (click then hold to change tint) without any gotchas. Does anybody who has one have any guidance on how to change groups reliably? How fast should those 4 click be to get it to switch between groups vs going into strobe on the 3rd click? I’m afraid to try it again since it was so hard to get it into ramping brightness in the first place. Hopefully I won’t accidentally change it back to stepped brightness mode until I learn the trick.
Not sure why the heck you would design a UI with 3 clicks to strobe but 4 clicks to change ramping groups. Seems like the average user would stumble in the same trap as me of going into strobe with click 3 and click 4 just turns strobe off (instead of 4 clicks switching between groups as intended).
I ran into the same difficulties with the IF25 - the first times I tried to do an electronic lockout or switch modes, I triggered the strobe and then turned it off.
Based on experimentation, it seems that a double-click can be fairly slow, a triple-click needs to be faster, and a quadruple-click needs to be very, very fast.
You seem to get the same window of time (starting from the first click) to make all the clicks - so the more clicks you need, the faster you have to be.
This definitely differs from Anduril, which I feel resets the window of time with each additional click - letting you chain clicks together even if they aren’t lightning-fast.
Those 4 clicks were about as fast as I could go with my fingers. It will suck if this goes back into stepped mode. It will take me another hour to get it back to ramping
I have many multi-click lights and have never had this problem on any of them except this one. I also have a technical background and I can usually figure things out without the manual. Maybe it could possibly be a difference in click timing between production runs that makes the one I received so frustrating.
I tried it, tried it again, then read the manual, then tried it again, and again. Not a good unboxing experience.
Bottom line - IMHO, this is not a good UI design.
And I’m not bashing Sofirn here. They make great lights. In fact, I have several other Sofirn lights and I like them. This one seems to have slipped pass the design review team (or maybe the QA team if the problem is possibly due to timing differences between production samples).
Have you used Anduril before? I find it much harder. 3 clicks stepped/smooth, 4x clicks for config mode and many times have had confused customers messing up settings
I also had some issues switching mode group with my first IF25 (similarly it took me a lot of tries), with my second one, no problem, maybe they tweaked the timings.
Answering Funtastic’s question: Yes, I have several Anduril lights (including the IF25A 4000K version). They can be complicated with all of the configurability, but they can be consistently navigated with the cheat sheet.
On the IF25 I have, the cheat sheet excerpt would look something like this:
3 clicks from on: Strobe
3 clicks from on (but at a different clicking pace which is not documented): You are on your way to 4 clicks
4 clicks from on: If you did 3 clicks from on at the right pace, then you will change groups. If you didn’t, then you will have experienced strobe and then turned strobe off.
It’s a nice even beam, more floody than the SST-20 but not overly so. I like it!
I am not what I would call an expert at reflowing but I have had pretty good success. I’ve used two methods where I clamp the board in my helping hand. Blowing from underneath with my hot air station until the solder melts or holding my soldering iron on the bottom of the board. Once I see the solder go liquid I pluck the emitters off with some precision tweezers and place the new ones on. It’s important to make sure there is enough solder remaining on the pads of the MCPCB especially the center thermal pad or you will cook your leds. Good luck!
Thanks for the tips, everyone! Once I muster up enough courage to mess with this light, I’ll give it a shot!
(I may end up buying a second one as a backup, juuuust so I don’t destroy my only working version of the light.)
I have no problems using multiple clicks on Anduril lights, but my IF25 purchased from Amazon US during the first week of November is very difficult to "quadruple click" fast enough to toggle between the "ramped" and "stepped" brightness modes (while the light is on) or to toggle between the "electronically locked out" and "electronically unlocked" modes (while the light is off).
Because of this I leave the light in ramping mode and loosen the tail cap for lockout to avoid using the "quadruple click".
The switch on my IF25 occasionally ignores single clicks (even though I hear and feel the click) and I need to click a second time and sometimes a few more times before it works. I normally press rubber switches using the pad of my thumb (to avoid damage from my fingernail) but the switch on the IF25 works more consistently when I press it with the tip of my thumb (maybe because it gets depressed further).
The IF25 is a unique light and a nice lantern with an empty white pill bottle used as a diffuser. I only wish the ramping brightness levels changed more slowly while near the moonlight level to allow for more control of the brightness level selected when you stop ramping.
