I had the same question. I clicked 4 times from on and the light flickers as if something had registered, but it was still stuck in step mode. I couldn’t figure out how to get it to switch to ramped brightness mode. I tried it about 20 times and eventually it went into ramp brightness group. Seems like the timing is VERY VERY picky! I think what I was seeing was the strobe mode flicker on click 3 and then on the 4th click it turned off strobe mode. I’m still not sure how to get it to change between the stepped and ramping brightness groups. The tint control works as advertised (click then hold to change tint) without any gotchas. Does anybody who has one have any guidance on how to change groups reliably? How fast should those 4 click be to get it to switch between groups vs going into strobe on the 3rd click? I’m afraid to try it again since it was so hard to get it into ramping brightness in the first place. Hopefully I won’t accidentally change it back to stepped brightness mode until I learn the trick.
Not sure why the heck you would design a UI with 3 clicks to strobe but 4 clicks to change ramping groups. Seems like the average user would stumble in the same trap as me of going into strobe with click 3 and click 4 just turns strobe off (instead of 4 clicks switching between groups as intended).
Thanks in advance for any help!
