for the mirrored key its 3.5$ shipped
I got ones that now also fit the socket 1:1 but need to assemble a few then running out of pogo pins
So the new ones can just plug right into the usbasp correct? I will wait for those then I will most likely buy 2 to play with.
HarleyQuin and Lexel, do you have pinout and pcb layout recommendation for the programming pin connector? I think it make sense to standardize something for easy use on many drivers types.
the only one for pinout and pad pattern I see so far is loneoceans pogoprog here: pogoProg - Small AVR microcontroller pogo-pin Header but it look like everyone using slightly different spacing and pinout?
Yes, a standard pinout and via pattern would be good.
Lexel, do you have a diptrace pattern for the via pattern you use? Thinking about adding this to the GT4 driver.
Diptrace Libary with different variants of them
http://www.metronixlaser.de/bilder/flashlight/programming.lib
Eh, 6 pads is so overratedā¦ 3 is more my style
Iāll give 6 pads a shot, though. Lexel, are all v3.2 fixed (not mirrored)? Or was the mirroring only on the 10-pin connector? I had trouble flashing this board (my first attempt at using your pgm key), but I think it was probably my driver design at fault.
Quoting this to say Iām still hoping somebody does a complete flashing kit that includes all the cables, plugs, clamps, etc. and this key. Convenience is a strong selling point for me. I havenāt started flashing yet for various reasons. Having a complete kit to buy from one place would knock out a couple of those reasons.
EDIT: Iād still want the kit to include the usual programming clip because I already own some drivers that donāt have pogo pin programming on-board.
If I want the key to be used on the bottom of the driver, do I apply the via pattern to the bottom of the driver or to the top of the driver? I want to get the mirror issues right the first time lol.
I assume it should be applied to the bottom of the driver since not all the patterns use vias?
This is how the pinout looks like on the bottom side of the driver, just want to make sure it is correct since I donāt have a key to test it with:
In looking at my assembled key from a couple posts above, this looks right to me.
Different topicā¦ I seem to be having trouble with (at least some of) my pogo pins. They donāt seem to be making full electrical connection unless I completely depress the pins and the sleeve itself makes contact with the pads. Is this normal? Or should I try some other pins? It makes trying to flash a chip extremely aggravating. I think I tried repositioning this stupid thing like 25 times last night before getting a good connection. :rage:
Thanks, since it does not look like I will be able to test it before it goes into production I wanted to double check.
You could try soaking them in Alcohol and pressing them in completely while soaking to work any gunk out of them.
I would also try putting a bit of downward/sideways pressure on them if possible to try to ensure that the internal pin makes contact with the sleeve.
That is all I can think of.
With the normal SOIC clip, I have found spraying some Alcohol on the clip and then flashing while the clip is still wet nets me an almost 100% success rate when I am having trouble flashing a mcu. Of course I try cleaning the MCU with Alcohol first but this seems to work when that fails almost every time unless the MCU is dead.
Yeah, I was thinking about doing a good cleaning. They seem like the should be foolproofā¦ Iām sure itās gotta be something simple and stupid (like dirty contacts)
Edit: itās a tiny difference, but I see I used 0.35mm drills instead of 0.4mm. Perhaps the difference in contact area isnāt helping either.
vs 3.2 is not mirrored all solder spots and the 10 pin header should work
it has been proven that using viases is more reliable than just pads, so if you can put viases on the driver do it
usually gold plating helps or one side soft like solder that was already cleaned from flux residue
I guess that also some Pogo Pins may be not good
Have you got the new batch of keys put together yet? I would like to order a few so I can test it out when they are ready.
I have the new boards and stencils here
also like 30 or so Pogo pins left
Ok, I want to order 2 of them when you have them assembled let me know. Thanks.
Are P50 B1 pogo pins suitable?
Yeah, Iām pretty sure those are the ones we all use (at least myself, Lexel, HarlyQuin, etc).
Yes, that are exactly the ones I use and Lexel had the same spacing between the pins, back then. So unless he did not change that, the P50 B1 should be good to go.
Nur US$10.38, kaufen Sie den besten 100Pcs P50-B1 Spring Test Probe Pogo Pin Dia 0.5mm Length 16.35mm Online-Shop zum GroĆhandelspreis.
https://www.amazon.com/gp/product/B019FGHZBG/
I bought both of these. I believe they were identical for the most part. I built mine with HQās key though. Thanks HarleyQuin - just make sure you choose the thin board when you order from OshPark (2 oz copper, 0.8mm thickness)
