Interested, please send code
To late to get a code?
I’m interested if it isn’t too late.
Ordered XHP and SST, thanks
You’d need something like a Samsung 30T to get the most output. I’ll just stick with a 40T, a 30T won’t last long so better I sacrifice lumens for longer runtime
gonna get a order a second. can i get a code for a xhp50.2
Ordered
Ordered Green XHP50
thanks
Ordered 1x green/SST40 5000K. Thank you!
Hi friend,
Is it still possible to get ASTROLUX FT02S for 40 USD?Tthank you for answer.
Well……I was just informed as a dealer for Mateminco that this model is still 30 days from being available. That’s ready from the factory, not from Banggood
No idea why Banggood allow the sale so early
I hope the first batches wont be plagued by some faults and errors due to being rushed to the marked.
I guarantee that they wanted it listed for the 11.11 sale, Sofirn did the same thing for their new SP35.
Hi, I’m interested if possible in a coupon, thanks!
You got mail.
Silly little question but I couldn’t find an answer
The XHP50.2 model is more powerful (in lumens) so the battery time will be shorter than the SST40 model ?
Is the difference considerable or is it about the same ?
Yes, that’s correct, it’ll be less. It’ll also run much hotter so turbo could be seconds
Ok thanks for the answer
Which battery would you recommend for the SST-40 version? For maximum run-time at reasonable output. I was thinking about the 4000 mAh 35A 21700 Samsung 40T. But would a 20A 26650 be enough too if one doesn’t care about maximum output? I was looking at a 5300 mAh 20A 26650 Vapcell.
SST-40 consumes 3 amps, so any good battery will do
