Thanks again TomE
Always great mods
It only looks not bad, but for modding this headlamp host is pure crap.
charger board is separate ,just driver swap. Ordered boost driver PCBs it should be so f…. cool ;))
Convoy have 21mm driver it can be replaced with this one ;))
Dang, Convoy may be bout the only headlamp/rt. angle head EDC I don't have... I bought like 3 of the Eagle Eye ones when they were so cheap, offered in colors, and with 18650 adapters. I got a blue, black, and silver and only spent the time to mod one :FACEPALM:
Ohh no, I don't use MTN drivers. I reflow my own from OSHPark driver PCB's, usually DEL's but many others as well. I got a hot air system - works great to remove components, either all or singles, even small in tight spots. Forgot what it cost but I got it probably from eBay, pretty cheap, nothing fancy. You can get those all-in-ones with soldering iron and hot air, etc., but I have a good Haiko iron - wouldn't give it up for anything.
JKK90 XHP70.2 version with dual 26650.
Do you have a source we can order the JKK90 SBT90.2 from? Looking for silver short tube if possible.
This would be one interesting little puppy to stick a 15W laser module inside…
Just goggle foxpro predator light firefly
Cylons, watch out!
Twosun now makes flashlights as well:
https://www.aliexpress.com/item/1005001854266385.html
Titanium 18650, 350lm, H-L-strobe.
That's a pretty handsome flashlight.
I found it accidentally. It has a mode ring on the tail. It is a bit like the solution from the Maglite XL200.
Link in the pics.
Whoa! Gotta be careful with that Devil-Level Brightness, though!
Yeah, and be careful with that “magnetic control witch”
That’s to be expected of the FoxHawk FH-666.
I’m not sure if a) this is a clone or b) this is a new light, but:
https://www.aliexpress.com/item/1005002013000704.html
Trustfire has released a headlamp variant of their fresnel lens light:
https://www.aliexpress.com/item/1005001475696937.html
Where do I get the jkk70 or 90?
Can’t find them
Can’t find them
AliExpress has the 90!
EDIT: Page Not Found - Aliexpress.com
EDIT 2 : And the 70 Page Not Found - Aliexpress.com
Link in the pics.
Mag XL200 doesn’t have a mode ring, it uses motion detection, rotating the entire torch.
Here we have what looks like a common 10180 twisty…upsized to 16340:
https://www.aliexpress.com/item/32802945956.html
The perfect flooder headlamp?
https://www.aliexpress.com/item/1005002097096919.html
I actually like it. Looks lightweight and easily upgradeable to CRI97.
