I just need low , medium, high and off . If I was to be attacked it would be over before I could activate the strobe mode . How many people actually know what an SOS signal looks like ?
I think the average person would interpret those modes in this way.
You want to drive 40w led in tiny D10 ? But yes, this driver can be 6V or 12V. PCBs on the way, ill get it in week or two. I will write some short modding instruction how to transform D10 to ultimate hi-tech
O.K. Probably the last and ultimate Lume1 inspired, TPS63020 buck-boost, Anduril, 3V LED driver for this nice & budged friendly headlamp.
Driver can output 12W with full (4.2V) and 6W with completely depleted (2.6V) battery. Acceptable PWM . All mode stabilization . Eficiency up to 93%. Have reverse polarity and thermal protections. 1 or 2 color aux led support. Lowest mode could be lower , but its fine.
Its the most advanced and balanced driver i ever made . Mission accomplished.
PCB:
Thanks for your answer!
I was hoping a more simple solution ,maybe buying a few replacements from aliexpress.
Nope ,no internet provider ,the username it’s from an satellite chanel package https://en.kingofsat.net/pack-viasat.php .
Best Regards!
That ‘O’ ring is Buna Nitrile and can be spliced with Cyano-Acrylic (CA) glue. The CA melts into the neoprene and can be as good as the original – not used as elastic but a seal. When gluing be quick and precise, there isn’t any time to move the ends into place. Any excess I remove with a very sharp X-acto knife, sometimes I use a razor blade as more precise.
There is an American supplier of all sorts of ‘O’ rings The O Ring Store – if shipping is reasonable.
