[77outdoor] High CRI + RED 660nm dual led headlamp D25LR
I am interested as it should be useful for camping.
Skilhunt offer both reflector and TIR versions of the H04 and presumably they sell a lot of the TIR version. An SP40 with a floody TIR would make for an even better headlamp in my opinion. For the record I use my SP40 almost daily but I cut out a circle of diffusion material and sticky taped it to the lens to make the beam more floody. I couldn’t remove the bezel to see if one of my TIR optics meant for a Convoy S2+ would fit.
Interested
It’s nice to hear that such a light is in the works!
That’s something I’d be very interested in, please update us when that project has progressed along further.
Good idea!
A TIR lens with wide angle would be nice.
I would buy one.
I did try to use TIR optics for Convoy S2+ on the SP40, produces a nicer (to me) floody beam (assuming for indoors/near use).
Although the S2+ TIR optics is a bit too “high” so I had to sand the TIR optics (bottom part) a bit, so the SP40 bezel can be screwed back properly.
I could never get the bezel to budge until I got hold of a circlip plier. A case of needing the right tool for the right job. Now that I got it removed I did the same mod. I applied some silver paint to the inner chamber (with a silver Sharpie) which may help reflect light out the front. Not sure if the efficiency is any better than a reflector + diffuser setup as I don’t have test equipment, but at least the mod is performed and I can always switch back.
Nice TIR lens! Could you please tell where you bought this? sofirn team is trying to find a good TIR lens for SP40 but outcome is negative. It will be great if you help sofirn find one for SP40 V2
Bought it from the Convoy store (1pc per degree). It is too tall for the SP40 without modification but the head is the right diameter. Not sure where Simon sources them from. Hope this helps.
Interested in 1.
But what I really want…
Is to have two different beam patterns. Flood on one side and throw on the other.
Use Anduril tint mixing UI from the LTI to allow mix and match of the two patterns: all flood, all throw, or anywhere in between.
My preference is the LEDs should be anything high CRI in the 4000k to 5000k range.
FB
Interested.
And also hope the AA 14500 light will be available soon
interested
Double 4000K, or 4000K and 660nm.
I would be interested in these options if available.
Interested if 1 or more sst20 4000k,!!!prefer 2700k if possible¡¡¡ + 2+ 660nm
interested.
3x SST20-DR on one side might prove more useful
I’ll again list my interest for at least 1-2. I’d love a small-ish 18650 headlamp with 4000k High CRI & (deep) red. Ramping and Type-C recharging would be amazing aswell :smiley:
Interested in hCRI 4000K
Same, this is going to be my next dedicated headlamp! (I hope). Ramping and Type C (and maybe voltage-battcheck?) are on my personal wishlist, as well as a nice diffused beam (like on the Wurkkos HD20 on flood, I love the light it produces!)
interested.
thanks
Red on the head is a good idea. Interested
