hi i’m interested in the Rovyvons
what is the password for the copper Rovyvon Aurora A9 copper?
https://deals.m4dm4x.com/2020/11/05/rovyvon-aurora-a9-copper-650lm-usb/
Thank you my friend
Not a bad deal with that seeknite even though shipping increases the price to $14.29.
Astrolux® EA01
XHP50.2 3500lm SST40 616m Anduril UI
TIR Ultra-Throw EDC Flashlight Type-C USB Rechargeable
26650 26350 21700 18650 Mini LED Torch
including lung and short tube!
available in Black / Blue / Grey Body
available LEDs: SST40 5000K/6500K XHP50.2 5700K/6500K
my Code MAEA01 saves you 28%
Specifications
Product name: | Astrolux® EA01 TIR Ultra-Throw EDC Flashlight |
Brand: | Astrolux |
Model: | EA01 |
Emitter Type: | XHP50 / SST40 LED |
Color Temperature: | 5000k
5700K 6500K |
Max Output: | XHP50.2: 3500 lumen
SST40: 2300 lumen |
Range: | XHP50.2: 521 Meters
SST40: 616 Meters |
Intensity: | XHP50.2: 68000CD
SST40: 98000CD |
Firmware: | Andúril UI |
Driver: | FET+1 driver. |
Battery Configurations: | 1x 26650,1x 26350,1x 21700 or 1×18650 Li-ion Battery (Not included) |
Charging: | Integrated charger via USB-C |
Switch: | Electronic side switch |
Material: | Aerospace-grade aluminum alloy |
Waterproof: | IPX7 Waterproof |
Color: | Black, Blue, Grey |
Weight: | 120g(26350 version),160g(26650 version) [without battery] |
Size: | 26650 version:
116mm x 41mm (Length x Head diameter) 26350 version: 81.5mm x 41mm (Length x Head diameter) |
User interfaces:
[1] By default the EA01 is set to use SMOOTH RAMPING. Instant access to TURBO mode is also provided.
[2] A more conventional STEPPED RAMPING UI is available if you like discrete modes level. You can choose how many steps you want.
[3] MOMENTARY mode is useful for signaling purposes or rapidly/briefly lighting up targets. To exit this mode, physically disconnect power
[4] MUGGLE mode uses a reduced output.
[5] It has an electronic LOCKOUT for safety but acts also as momentary low light.
To know about the exact source code used in the product, please go to:https://tiny.cc/TKAnduril
1 x Astrolux EA01 Flashlight
1 x Lanyard
Astrolux® Colorful Filter For Astrolux FT03 FT03S (70mm)
The ST04 coupon code is saying "Invalid Coupon Code".
NEW Lumintop Worm damast/mokume/copper/brass/SS available!
coupon: BLACKFRIDAY gives 35% off
Hi Martin, not sure if anyone asked this before, is there a deal possible for the Thrunite T2 ? Not sure even where it is sold.
I need to ask a few
Tnx!
Max,
Thanks for coupons. I’ve been looking for a X9L Copper coupon all over. I’m having trouble seeing the price when I click the link above for the X9L page. Can you persknal message code or instructions? Thank you!
Do we know if the mode order is L > M > H or M > L > H?
i sent you the passwords
for my curiosity:
the text says " This content is password protected. Please contact us to get access! "
and there is a "CONTACT ME" link / form in the top menu
not clear enough?
does that need to be changed?
yes,
GT3 is blocked due to the sale i guess
from Lumintop:
H-M-L with memory.
Not my favorite mode order, but it’ll work. Thanks Martin - I just ordered a Damascus Worm using your link and the BLACKFRIDAY code. It’ll be my first Damascus light; I’m looking forward to it!
:beer:
thanks
