gonna get a order a second. can i get a code for a xhp50.2
Ordered
Ordered Green XHP50
thanks
Ordered 1x green/SST40 5000K. Thank you!
Hi friend,
Is it still possible to get ASTROLUX FT02S for 40 USD?Tthank you for answer.
Well……I was just informed as a dealer for Mateminco that this model is still 30 days from being available. That’s ready from the factory, not from Banggood
No idea why Banggood allow the sale so early
I hope the first batches wont be plagued by some faults and errors due to being rushed to the marked.
I guarantee that they wanted it listed for the 11.11 sale, Sofirn did the same thing for their new SP35.
Hi, I’m interested if possible in a coupon, thanks!
You got mail.
Silly little question but I couldn’t find an answer
The XHP50.2 model is more powerful (in lumens) so the battery time will be shorter than the SST40 model ?
Is the difference considerable or is it about the same ?
Yes, that’s correct, it’ll be less. It’ll also run much hotter so turbo could be seconds
Ok thanks for the answer
Which battery would you recommend for the SST-40 version? For maximum run-time at reasonable output. I was thinking about the 4000 mAh 35A 21700 Samsung 40T. But would a 20A 26650 be enough too if one doesn’t care about maximum output? I was looking at a 5300 mAh 20A 26650 Vapcell.
SST-40 consumes 3 amps, so any good battery will do
3A, what? This is a quad set up which is rated at 7000 lumens (SST40) and XHP50.2 is 11000. Certainly isn’t 3A.
I’m personally going to sell these with a Samsung 40T. I don’t have much knowledge on which 26650 would suit.
I’m sorry, but no. The SST40 version of this light will draw much more then 3A, I’m guessing well over 20A on turbo. I’d look for batteries with 25A CDR or more for maximum output. Samsung 30T, 40T, Molicel P42A, Golisi S35, the Vapcell gold 4000mah 30A (rewraped 40T), Xtar INR21700 (P42A rewrap) are the ones I can think of. I ordered the XHP50.2 version and will use the Molicel and Xtar 21700’s for experimenting and showing off and the Liitokala Lii-50A 26650 for regular use. It’s good to about 20A (not 50A).
I’d recommend getting your battery output figures from online tests and reviews and not the battery’s label or sellers claims as almost all are overrated by their manufacturer/distributors.
The PLB 26650 that Sofirn stocks is very decent. Continuous discharge is 10A but I ran a 20A test and it performed incredibly well. Last test graph on sofirnlight.com is mine.
Astrolux FT03 XHP50.2 version
PLB - 4000 Lumens
40T - 4200
+1. I also prefer 21700 over 26650 nowadays.
Looks very promising, Could I also get a coupon code ?
