【convoy】H4 and B35AM options are updated
Well, I am glad to hear that, but you said it was not suitable earlier:
Love it.
What is the beam pattern like in S2+ with red light?
few of the groups in the 5 groups have a strobe. what kind of Strobe does it use ?
Just built 2, Green and Red (i don’t rember exact PartNumber)
Red is running on 2.5V driver and Green on 2.8A Biscotti driver
Now i need Blue and Amber.
Also there are likely many customers buying lights from Simon that don’t know how hot a li-ion powered flashlight can get, especially when left unattended. I’ve seen several people on r/flashlight that wrecked their older S2s by leaving them on higher output for ceiling bounce, etc. Sofirn for example ran into a similar problem when they were getting bad reviews on lights simply because they were getting warm on turbo. I can’t imagine the consequences reaction if these lights were sold without any sort of thermal regulation or even just timed stepdown.
Looking good.
For the 2.5V red light.
Did you have to solder the driver to the pill? Retaining ring?
Earlier in this thread Simon said the red driver wouldn’t be suitable for the S2+ pill.
I did solder the driver to a pill, common in previous versions (2,8A Star FW)
I did not even try installing retaining ring which might even fit O_O
Perfect.
Thanks for the clarification.
I am new in building flashights by myself, could you please take a picture of how you have soldered driver to a pill?
I did solder a 8x driver to a brass pill for a S2 mod once, and it was a total mess :
As the pill takes all the heat, the solder won’t stick to it, I finally succeeded using open flame soldering, getting the whole pill enough heat that it could melt solder by contact … worked fine but the result is not pretty
Yeah, not so nice but it’s working
Much better than what I came up with !!
I found that the solder on sticks to the top surface of the pill
Thank you. I will try this myself.
ferrat_val you can solder to pills with heat guns. I for example own a 650W PG8018LCD, and it rocks:
Bought it here long ago (not affiliated).
A heat gun is in any case a very recommendable tool for electronics work.
Perhaps opportunistic, but do AliExpress coupons stack with discounts that Simon may give? I’ve got a project I’m working on, and am trying to do it in the most cost efficient way I can.
I recently got an M3 from Banggood in a flash sale not realising that a version with ramping (and charging!) had finally been released.
Yes it does. Apply your coupons, select some alternative payment method you can discard and then proceed to message Simon. Done.
Thanks, will give it a try.
Edit:: hmm looks like I can only do credit card or PayPal. I might have missed earlier in the thread if you do PayPal and then just not pay….?
You must see WebMoney, choosing WebMoney works. Choosing PayPal should also work no problem. Just dismiss the payment page in any case.
Alternatively, you can use AliExpress application 8.4.0 or earlier. With it you can select “other payment methods”, the archetypical way. The app checks for updates just on startup, it counts the number of times it asks you to update and after a number of refusals it ends up forcing you to update (or clear }) application data). This is solved by launching the app while on airplane mode, while it shows the launching advertisement. As I've found many times, old versions of software can be better.
Sat, 11/28/2020 - 03:32
Yeah, WebMoney doesn’t appear for me.
Looks like it’s a moot point now; the coupon I had was for Black Friday and has now expired, it seems. I’ll send Simon a message at some stage.
