That’s because Covid was supposed to be rare at the beginning and early symptoms/mild cases can be confused with colds and the flu. If 1 in 10 had the Flu and 1 in 1000 have Covid, if the odds are independent then still only 1 in 1000 Flu cases also have Covid and the other 999 only Flu, you may have very bad luck but wasting limited tests on a 1/1000 chance was overkill. The odds are not really independent because they are transmitted the same way but for low rates it doesn’t matter much, when the rate of Covid increases it becomes a different matter.
OTOH infections may indeed interfere with each other, the most basic way is that once an infection is detected the inmune system will become more active but there are more sophisticated mechanism that I don’t really understand.
The reason that report was pulled from the student newspaper website at Johns Hopkins (yes, it was posted by the student newspaper, not by the medical center) is that the conclusions provided by the economist who wrote the report are based on very limited data and speculations that are dubious at best. For example, the report suggests that the data show that the percentages of various age groups who have died during the pandemic have remained relatively stable compared to previous years - and then goes on to assert that data prove that the virus hasn’t killed many people. However, that conclusion doesn’t necessarily follow from the data cited. The normal death rates among various age groups might have remained relatively constant during the pandemic, contrary to initial expectations that older people would disproportionately die in greater numbers than young people, because a lot of young and middle-aged people have died from the virus, as well as older people. Whatever the explanation for the data, and again, the very limited data cited in the report at issue, it does not prove that few people have actually died of Covid-19.
Moreover, the other major dubious assertion made in the report, and I suspect another major reason for the report being removed from the website, is the assertion in the report that Covid-19 must have killed far fewer people than previously thought, because reported death numbers from other causes have decreased compared to previous years. The report suggests this is evidence that deaths attributed to Covid-19 were, in fact, due to other causes. Again, that conclusion is based on an assumption that the numbers of reported and actual deaths due to non-virus causes are the same - an assumption with no evidence to support it. In addition, the report also assumes that the fact that deaths from non-virus causes went down in 2020 compared to previous years proves that many deaths attributed to Covid-19 were in fact caused by other conditions. The report provides no evidence to support that assumption, either. Another obvious possible reason for non-virus deaths declining would be that the virus killed a lot of people with co-morbid conditions, therefore ending many peoples’ lives before the other conditions could kill them. But the report doesn’t entertain that possibility at all, for some unknown reason.
Then, there are the independent analyses of the excess deaths in the USA during 2020, which have uniformly come up with a figure roughly approximating the number of Covid-19 deaths cited by the major sources of data, like the CDC, and have also concluded that the official figures almost certainly undercount the true number of deaths caused by Covid-19. You can’t just assume those analyses away, especially since they’re based on a larger data set.
Apparently someone infected can buid up enough virus toreliably be detected in just 7 to 10 days, rather than needing to wait the full 14 days before the test will detect the virus.
Regarding excess deaths I have heard the argument from many that somehow this isn’t real. Do not understand how that could be a reasonable assumption given the appearance of temporary morgues and mass graves all over the world. Probably spent too much time looking into this but FWIW, here is an overview of a variety of studies on the topic.
