Sst40’s have a real low vf and will easily pull 8A when driven hard on an fet. The Ft02s has a an fet driver so it will largely be limited only by the thermal control on the driver and battery. The xhp50.2 3V has a low vf also, and easily pulls 13A or more when direct driven. This light will pull some serious current in either configuration. A 25A capable cell is recommended for max output- asung 30T, 40T, or Molicell P42A 21700.
I see Nov 29 in my app but most likely after BFCM sales?
Hello freeme! I have not received the code! Can you send me one? Thank you!
There is the Golisi 26650 that can handle 30a
My order was placed on Nov 10 & it’s now indicating estimated to ship on Dec 10! Too bad!
Can I get the coupon code also? Thanks!
Ok, I had a brain fart.
I see I need to also order batteries. I have the XPH5.0 11k lumen
What would the best battery be for max output and run time? Also how many do i need?
Any recommendations of where to get them?
Me personally I like the Shockli 5500 mah 26650 if a light takes 26650
I’m interested an i have a coupon please
Thanks! I appreciate it. Does this light only take one?
PM sent.
ordered thanks
Order placed ! Black xhp50.2 6500k !
Thank you. Ordered sand XHP50.2 5700K
I’d be interested in the code.
Could I also get a coupon code
Could I also get a coupon code?
Thanks. I bought a Sand xhp 50.2 6500k.
Interested in the sst-40! Can I have a coupon please?
Sent.
