FREEME ✌ ASTROLUX EA01 SST40 (2300lm)/ XHP50.2 (3500lm) TIR 26650/ 26350 Flashlight Group Buy - ALIVE!
Interested
Interested.
Sent.
Interested…
Sent.
Ordered Blue XHP50.2 5700K.
Is it a 20mm board for the LED? Perhaps switch it with the SST40 in the FT03 if possible.
Thank you pal!
Thanks!
I think very few people here are going to disagree with you on this. And defintely don’t think you’re offending anyone. Until Samsung/Panasonic/Sony starts making 26650’s, 21700 are the way to go.
The best 26650 cells can sustain significantly higher currents with much less voltage sag than 21700s of the same capacity. Not a big deal for lights drawing 10A or less but for lights with multi or high-power emitters there is definitely an advantage.
Just like we now have some 16340, 18350 and 14500 with newer chemistries the same will almost certainly happen for 26650 down the road as wel.
I did not know about 26650’s better handling of voltage sag with higher current loads… hopefully we see manufacturers putting more effort into developing non battery pack 26650 batteries. I was defintely against the 21700 movement until about 4 months ago, mostly because I needed a new charger for them. I was totally on the 26650 team until I experienced the array of lights using 21700’s, and there benefits as well. I have some Efest 26650 4200 mah purple that are pretty good, but my ft03s for example seems to run better on the 40t’s. Who knows, I have no way of measuring it afterall.
Interested in blue xhp50.2.
Thanks.
Interested! please send my the codes, thanks.
Im in.
Tanks Freeme
Robert
Thanks for the coupon, ordered.
I have a question, do you know if this flashlight work with flat top batteries? i want buy Vapcells and need know this, thanks in advance.
I am going with the assumption that YES it will work with flat top batteries, already ordered a couple extra 40t’s… Hope i’m right lol.
Interested
I’m interested. Thanks!
Ordered Blue SST40
Nice light list! Question - which GT do you like more? The xhp35 or 70?
Sorry about the random question…
Art
