I’m thinking to buy either sp10s again just for the sake to use the old one for spare emitter or buy convoy t2. Is convoy t2 easy to fixed and more durable than this sp10 series ? Hearing from your experience , seems it’s not good to buy another sp10s.
I was not saying that the SP10 isn’t worth it, but it needed to be potted or have and internally different structure to be more solid.
As for the T2, yes, it is much easier to fix in case the driver or the emitter are damaged! And it is more durable, the walls ate thicker it can handlea beat better than the SP10 lights.
I’d park the SP10 for a while and maybe try the Convoy. Then… when Sofirn has a cool new light you want later down the line, you can add the SP10 driver for the free shipping, get a new light and fix the SP10 later. I’ve done this with a few lights over the last few years (and Sofirn was pretty good at finding non-listed parts for me a time or two, too).
I have about 5 SP10s- dropped a few but knock on wood- never had one fail and I’ve put them through some paces. But if you need a 14500 right away I concur with the Convoy. Simon makes super good lights (inside and out) and keeps them simple and durable and the T2 is probably the more durable (and easier to repair- like my Chevy’s)!
Quite a lot of manufacturers won’t give a warranty for damage incurred by the user. If you think about it, if Apple says their iPhone model has a 2m waterproof rating and it gets water damage by any measure, the warranty is void. Same for any phone manufacturer. Same for drop damage etc
Letting something like this put you off an entire brand is a bit much. If you want something that’ll take a beating, then get a brand that pots their drivers. Something like the expensive Elzetta brand
Every single brand that’s not potted won’t be durable like you’re wanting. The SP10S driver most likely has had a component shift from the drop and that’s just what happens to solder. The prices you’re wanting to pay, you can’t expect a whole lot more tbh. Most have had an SP10S take a beating and function fine, others not, but that’s like every single product that exists, some have faults etc.
So you’re saying if the SP10S had thicker walls it would have survived? I don’t think so.
As for fixing, the T2 is much easier but you still need to know how to solder
Nop, I was saying that the T2 is more durable and has thicker walls, but I wasn’t comparing walls thickness with the SP10S.
I was also saying that the internal structure of the flashlight (driver shape, shelf, wires bending, etc) has a negative “impact” when the light falls to the ground.
On a T2, a “regular” 17mm driver can be used, un/soldering wires and it stays put and has no other elements affecting it negatively if it suffers impacts on the floor.
Well and for this kind of replacement and fixing you’ll always need to know how to solder and have the tools, but it is way easier to replace a driver or fix something in a T2 than in a SP10 light
One of the best things about Convoy is their lights never use glue, it’s fantastic for modding
Convoy is my best selling brand
I know a little basic knowledge about soldering. I used to fix / remove mechanical keyboard switches. But flashlight pcb is much smaller and it seems i dont have tools like heatgun to remove the glue. And also removing the driver seems hard without damaging the driver in sp10s.
I will try use the hair dryer to heat the glue. I better buy another flashlight than buying a heatgun.
Glad to hear that convoy is much easier to fixed. Gonna pick one with lh315d 4000k. Already order nichia 219c in tool aa. I think zappaman is right, i will wait until sofirn make sp10 with anduril which everyone are waiting for and order sp10s driver along with it.
You could use a hairdrier and solder a bit of wire to the driver and try giving it a tug, this is how a couple members do it. You first need to unsolder the wires off the led though.
Just a minute there. (taken from AliExpress)
It’s clearly stated the flashlight can withstand a 1-meter drop.
And the user just so received this light.
It’s not like he threw it against a wall/floor.
Accidents can happen. What are we to pamper our lights, cotton ball and all?
It’s not like he threw it against a wall/floor.Accidents can happen. What are we to pamper our lights, cotton ball and all?
Yes, but, all manufacturers will say that any damaged caused by the user isn’t covered.
I’m a dealer for Mateminco/Astrolux and they said if it’s dropped or damaged in any way by the user, the warranty is then made void
Same thing with any phone brand, zero warranty if it gets wet, even though it had a IPX8 waterproof rating.
If you just purchased an iPhone and it drops off your bedside and cracks, are you covered, no.
I’m sorry, but that argument is not legal tender.
If a product states that it is tested against such, then that is binding.
I’m in a province where any product is legally bound to cover any marketing claim including waterproofness. If the product does not withstand a drop/dunk, and is such stated, it is covered by the law. Also, this makes your statement give the manufacturer claim to just about anything and not abide by their own statements.
Come on Funtastic, companies don’t have the right to lie, and weasel out of responsibility when a $10-15 light accidentally drops from a table.
PS, Apple does not claim its products waterproof. And they don’t claim a drop test on their phones or tablets. Quite contrary. Apple clearly states their products are not waterproof nor drop-proof. If you are inclined to have such accidents, then you purchase AppleCare.
It is not user abuse, but the fact Sofirn clearly states it can withstand a 1-meter drop. It did not. And the burden of liability is not on the purchaser but on the manufacturer.
Well, I’m just repeating what I’ve been told by every brand I stock.
If not Apple, then many Samsung phones give a waterproof rating but warranty is void if it gets wet.
For New Zealand, I still have to give cover (consumers guarantee act) but I don’t get any replacement by the supplier.
For some of my models I don’t state an impact or waterproof rating since not all specs are accurate. I don’t have to provide a warranty on a spec I never claimed
As you can see, Apple gives no warranty for liquid damage. If a customer is covered under consumer law then it comes out of the seller’s pocket
Apple sells their own products in each country so they’d still need to cover under consumer law. It’s entirely different for products sold from resellers. Overseas brands don’t have to provide cover and the warranty replacement then becomes the shop/seller’s expense .
And there you’re correct. You don’t give a warranty for specs that your better judgement says are not accurate.
Sofirn states that the light can withstand a 1-meter drop. They are the claimant and so are liable if the product does not abide by such claim.
All phone companies here clearly state their products are not waterproof, nor drop-proof.
And it states there that the user has rights under consumer law. I’m having trouble with the fine print…
Consumer law states it becomes the manufacturer or issuer of the product that is liable.
Edit; I had misread your statement.
I just edited it to be more clear
The burden of liability is on the person that makes the claim of warranty. If the product is sold thru Apple Store, then it is Apple Inc that has the onus of responsibility. If the statement is a marketing ploy by a seller, it is that person that takes responsibility.
I don’t know of overseas liability, but Sofirn sells in Canada, they are held accountable. Even if one was to purchase directly from their manufacture. They would have to state the product is not covered, specifically, and clearly marked prior to purchase.
The fine print clause or the detailed/legal EULA is notwithstanding here. Courts dismiss any claim by the makers - it cites with the consumer in most cases. It also has a system in place that the consumer doesn’t have much legal burden, just some paperwork and the issue is resolved between Government and Company. As a matter of fact, there is a hotline (actual phone number) when a consumer is at odds with some seller or a customer service rep.
It actually boils down that companies cannot make false claims, nor sell under assumptions.
But this is getting away from the liability that Sofirn has a product, a $15 light, that they care not to cover. It is rather cheap and scrupulous of them.
As a merchant, you have rights and obligations. I understand that. In your understanding of the warranty, it is according to New Zealand law. I have a different view from a more socialist environment. But you didn’t sell the light to Timber, and I can’t vouch for his rights.
But if he purchased it directly off AliExpress or Sofirnlight.com then he’s not covered by any consumer rights in his country.
In New Zealand we have a platform called Trade Me and all overseas sellers are under the CGA, but if I was to purchase directly from say their China website, I have no cover whatsoever.
As I’ve said above, all companies will say the same for impact and liquid damage.
I find impact damage hard to give a warranty for, as many people lie about the height and also many times it’s not just an idle drop, but with some force. I had a customer slip and “drop” his FT03 but as he slipped he threw his light to the ground, claimed it was a straight drop to start with. Mateminco/Astrolux said no warranty cover and I had to pay for new parts. Luckily upon inspection it was just a crooked tail cap preventing a connection.
