With my FW3A with tailcap retaining rings I noticed that if the retaining ring was full snugged down the switch operation was spotty. I think this was because the ring was forcing the switch board into a position that isn’t quite flush with the inner tube, resulting in an insufficient contact between the edge of the inner tube and the trace for it on the bottom of the switch board. As a result, my second generation FW3As with retaining rings were actually less reliable than my first generation ones without.
Fortunately, this is very easy to fix. The main thing to keep in mind is that the switch retaining ring is just there to keep the guts from falling out if you take off the tailcap. It should NOT be snugged down tightly. loosely screwed in works better as that allows the switch board to float into the correct position.
speaking of retaining rings, I was hoping to reflash my FW3A with Anduril 2 and can’t get the retaining ring out. This isn’t glued is it? wouldn’t make sense to do both, but so far its not budging.
I think I found the issue. Seems the FET has been wrecked. I measure 1.7kOhms Source to Drain. Should be in the MegaOhm range I reckon… Swapping the FET out now and will report back.
EDIT: Well… I was wrong. Go figure!! lol Removed the FET and it still had the leakage current. Then got super lucky and the first 7135 (U3) I removed was the culprit. Replaced that bugger and now we are back to like new!!
Hi, i am in trouble with reset.
Any help?
I try 4 times to rotate the head after click and press switch with battery inserted.
The light ramp low to high but it do not switch off.
Any help?
What does it do when you try to switch it off? Does the led glow very faint or does it stay at it’s set brightness?
If it ramps, that means the switch is working.
I Buy FW3A 31 Ago 2019
If I try to click 13 times nothing happen
For reset I have to unscrew the tail and press button before screwback.
I don’t want to unscrew tail so I do the reset with the head
To make sure the reset has been done I try Ramp mode but there are 4 levels and not 7…so nothing as been reset
Power is connected before the signal tube for the switch, so holding the switch doesn’t work. You have to do 13H. If it doesn’t work, the light does not have factory reset. Lumintop was very late with using a newer firmware.
From off, try 13 fast clicks and hold the last one. The led should do something.
Or try 13 fast clicks and hold on the 12th or 14th one.
I don’t have the later model, so I’m not sure.
From Toykeeper: From a regular “off” state, click 13 times and hold the last click for a few seconds. Then keep holding the button for 3 seconds. The light should flash an increasingly bright warning, during which time the user can let go to abort without any changes. Then after 3 seconds, it gives a bright flash and fades back to nothing. This indicates the reset has completed.
I don’t remember where, but I read in forum that I have to press the switch for 3 seconds after screw tailcup.
There is a mode for understand if my fw3a is compatible with reset or not?
