Vapcell INR26350 2000mAh A20 (Red) 2020
Official specifications:
Battery size: 26350
Battery chemistry: Li-ion
Voltage: 3.7V
Minimum capacity: 2000mAh
Maximum discharge current: 6A
Height: 35.00mm
Diameter: 26.10mm
A 26350 sized LiIon battery, this is a uncommon size.
The two cells match nicely and can deliver the rated 6A, but not much more.
Conclusion
The batteries works fine, they are neither high current nor high capacity, but the size is not very common.
Notes and links
The batteries was supplied by Vapcell for review.
Graphical comparison to 18650 and other batteries
Table with all tested LiIon batteries
