The 130g weight spec’d is the the flashlight and head strap together, no battery. I don’t know why they did this, but it’s the only thing that makes sense.
The actual weight of the HD20 with no battery, no clip is 87g, not 130g.
Hey Wurkkos. I ordered the HD20 with the battery and it seems to have a flashing red during a 90 minute charge. The charge indicator never turned green. Via the manual it says the battery is critical so I tried swapping it out with another battery and the problem was not resolved. I ordered the light off AliExpress on 11.11.20. Any advice on this issue would be appreciated. Thanks.
My FC11 is a solid red when charging. I looked around and found info regarding the below. I don’t think my battery would still be below 3% after a hour charge. Also the other batteries tested were running well in other flashlights.
3% > Flashing Red
30% > Constant Red > 3%
Constant Green > 30%
We Tested discharge of HD20 again (batch 1#) different phone and products shows different discharge current, so different equipment will influence the reverse charging current.
A remark : for the turbo i would like the annouced first, ie both flood + throw instead of only the led used befor going TURBO. I will use it on flood for the main part and may need turbo on throw while lost in the wilderness.
