I think those two pictures are misleading (not on you, just not meant to be compared I guess?) Holding at different angles and one being held with two fingers Maes it look much smaller.
I think of it as comparing a C8 to a KR1… same class? I don’t know? meaning it is subjective and how do you view flashlight carrying… I think once something is not pocket carry-able (in jeans) then it is a different class. thats just me. although I don’t seen either of these being carried on a clip in my jeans, they both look too big for that. the X9L is the max size I would or will carry in my jeans pocket.
Yep that’s the biggest issue I have with these non regulated drivers. I use my lights for long durations and sometimes tailstand them as work lights. Here are some comparisons between large lights with unregulated drivers vs small lights with regulated drivers.
FT03S SBT90.2 weighing 298g stabilizes at 141 lumens
Emisar D18 SST20 4000K weighing 343g drops to about 500 lumens
Olight Warrior Mini with SST40 weighing a miniscule 55.8g stabilizes at 530 lumens for almost 4 hours!
Astrolux FT03 XHP50.2 weighing 295g maintains average 500 lumens even with fan cooling for 2 hours on a 21700. This is about half the runtime of the 18650 Olight Warrior Mini despite the Olight uses a less efficient emitter and less battery capacity. That’s the beauty of having a high quality driver.
Lumintop FW21 Pro 3xXHP50.2 weighing 120g stabilizes at 200 lumens with fan cooling.
Despite the Olight Warrior Mini weighing a small fraction of the other lights, have the least surface area (most important for shedding heat), and uses a less efficient emitter than the rest, it sustains higher output and is much more efficient (area under the curve) than the rest. I just wish more flashlight fans understand the importance of having a good driver and not simply buy based on the lumen output that last a few seconds.
140 Lumens seems low for the FT03S. Doesn’t it have multiple 7135s? The FW21 Pro can run at 6/7 stable. 7/7 (over 1000lm) is also regulated but the output drops to about 80% after a while in my 23°C room set at 65°C. Would love to see a 4 LED version with a high efficiency driver.
Sense is the word that should not be used here, there are 12LEDs running in direct drive, so going 6V to lose the actual running power of the forecast top lumen output?
You won’t be direct driving 12LEDs from a FET in a 6V output from an actual 4.15V cell after charge.
You can claim if you want a 10A buck driver, that does not mean it is even going to be constant current from a single cell, but you can claim it and it would still be a buck driver even if it not regulated at 10A at all.
That’s not the norm but you can easily test it out yourself and see. You can’t expect these reviewers to test every single usage possibility out there. You can download the ceiling bounce app if you don’t have any other equipment for testing output and verify it.
A couple years ago I used the MT09R and MT03 as work lights in very large interior spaces and was sorely disappointed how they quickly drop to unusable levels. And no I don’t start it on turbo.
I just successfully placed an order for E12R with Nichia 219B sw45k! I also ordered NOV-Mu with E21A R9050 2000K.
There are more emitter types available now, all of them seem to be in stock:
SST20 6500K 10W CW
SST20 10W 5000K NW
Sumsung LH351D 5700K W2 CRI80 (+$15.00)
Sumsung LH351D 4000K CRI90 (+$15.00)
Nichia 219B SW45k D220 R9080 4500K (+$10.00)
CREE XPL2 HD W2 6500K (+$30.00)
Yeah couldn’t resist the 219B-V1. Thanks for offering that. I really hope there are no first batch quirks like with the E07, I got the sharp edged fins and a mushy switch back then.
Should be doable with a Samsung 30T. Even the TM9K can make over 9k OTF with 9 XPL2 using a low current 5,000mah, despite it is built-in with soldered terminals for minimal resistance.
Can you please tell, do fireflies send you some confirmation, tracking number, etc. Ordered one about 2-3 days ago and still got nothing except PayPal email
Some help?
Wow, things have changed a bit on the flashlight horizon since my last season of hanging out here!
This looks like an well-designed pocket light. I have the E07, and love it.
Could someone give me a BRIEF rundown of pros and cons for the offered emitters? Last time I was on here a lot, the crowd was about evenly divided between the “most possible lumens Cree” folks and the “rosy at all costs Nichia” folks. I’ve never even heard of the Samsung emitters!
So what the pluses and minuses between -
SST20 Group
Samsung group
New Nichia offering
Cree XPL2
And sorry for my remedial memory and knowledge!
(in the past, I have leaned towards the higher lumen options, but not the completely ugly end of that spectrum)
the beam “points”/is slightly “throwy” compared to the rest but not compared to reflector light. beam color is not great, CRI is very low, overall lumens good
SST20 10W 5000K NW
the beam will be floody and make a very round/even beam from edge to edge. beam color is ?? but probably ok since it’s even, CRI is middle of the raod, overall lumens good
the beam will be floody and make a very round/even beam from edge to edge. beam color is may be faint lime color indoors on white wall, outside it will be fine, CRI is GOOD, overall lumens good
floody beam, fairly even across beam. tint will be pinkish color indoors/white wall but normal outside. CRI is VERY GOOD, output is LOW compared to other options
you couldn’t pay ME $30 to choose this option. It will be very high lumens, low CRI, very floody, probably not very even beam
