WTS/GB: [4000k ARRIVED, Test Report's In] GT-FC40 (a.k.a. XHP70's flattop, 12v 40w sister) 95 CRI, Available in 4000k, 5000k
168 posts / 0 new
Unloco
Unloco's picture
Last seen: 2 months 3 days ago
I am interested.
Does it work with H2-C?
rngwn
rngwn's picture
Last seen: 2 months 5 days ago
Yes, it does work with H2-C.
As always, you may need to bypass your host’s terminal to reduce contact resistance.
Agro
Agro's picture
Last seen: 3 months 6 days ago
Lumintop GT3 would make a nice host for GT-FC40:
https://www.nealsgadgets.com/collections/new-arrival/products/lumintop-g...
12V TA driver stock…
Though a little expensive.
id30209
id30209's picture
Last seen: 3 days 21 hours ago
Ouch...
I'd rather go with Convoy M21C-U and ask Hank from Intl-Outdoor to buy K1 12V driver if ramping is desirable.
Or as i did, M21C host, Convoy XHP35 driver and FC40 paired together in an awesome combo.
WTB Titanium 4sevens 2xAA tube
Unheard
Unheard's picture
Last seen: 2 hours 44 min ago
Naiv question: The R50 pro only uses 6V XHP70, correct? I imagine a domeless LED would give it the missing throw.
Don’t own the pro since it’s inferior in this regard, but if there was a nicely tinted, throwy LED, I’d be tempted.
Spitzbube.
id30209
id30209's picture
Unheard wrote:
Naiv question: The R50 pro only uses 6V XHP70, correct? I imagine a domeless LED would give it the missing throw. Don't own the pro since it's inferior in this regard, but if there was a nicely tinted, throwy LED, I'd be tempted.
GT-FC40 is 12V and if R50 is running on 12V then you could swap emitters without problems.
But if it's 6V then you won't light it up with FC40.
Unless you are talking about shaving the dome on the present LED installed in R50, then yes, you will get more throw
zak.wilson
Last seen: 1 month 4 days ago
A4 bin 2x, A5 bin 1x.
In the event the A5 bin won’t become available for a long while, then A4 bin 3x.
Ceilingbounce – flashlight testing and runtime graphs for Android | Zak Reviews – my flashlight reviews, with lots of runtime graphs
id30209
id30209's picture
Thanks to zak.wilson i have made another great host even better.
Thrunite T2 is now highly desirable item
I just realised i’m running out of FC’s O_O
thefreeman
thefreeman's picture
Last seen: 17 min 35 sec ago
Looks great.
I just want to mention that the glass lens on my T1 added arround 0.0020 duv, have you tried without the lens to see if there was any difference ?
id30209
id30209's picture
thefreeman wrote:
Looks great. I just want to mention that the glass lens on my T1 added arround 0.0020 duv, have you tried without the lens to see if there was any difference ?
Mine is coated with Joshk miracle paint called “green delete” Smile
id30209
id30209's picture
Aaaand with this build i actually used all of them.
So...payment sent for 3ea, tracked shipping.
Thx!
djozz
djozz's picture
Last seen: 3 days 3 hours ago
How can the Thrunite T2 modded with this led? Is the XHP70 from the stock light circuited for 12V?
Edit: never mind, found the answer in another conversation: yes it is used at 12V configuration Smile
zak.wilson
I just discovered it’s 12V today after my second attempt at getting the bezel off. My thoughts went immediately to this emitter, and I just paid for three of them.
thefreeman
Ah ok then, but if the lens is doing +0.0020 then paint say -0.0020 then it’s like using a good lens but with light losses along the way.
id30209
id30209's picture
thefreeman wrote:
Ah ok then, but if the lens is doing +0.0020 then paint say -0.0020 then it's like using a good lens but with light losses along the way.
I haven’t noticed output drop with this paint as Joshk also confirmed. Maybe after 2-3 or more coatings but not with thin 1 layer i have. It’s not like Lee filters...
lukehale
I JUST ordered a T2 and GT-FC40s to do this exact same mod. AND I plan on using my Green Delete too. How did you manage to get yours apart? And how is the output relative to stock?
I’m very excited to get mine done!
0oklight
0oklight's picture
I am very inspired by this T2 mod too, having had three of the LED’s lying around for a couple of months.
Does anyone know if the 12v driver in the T1 will drive this LED at less output in comparison with the driver in the T2?
michikuri00
Last seen: 8 months 3 weeks ago
One 4000K please, if still available
thefreeman
If I remember correctly it is 1A. I don’t know exactly about the T2, but zeroair measured 4000 vs 1600lm, so it’s much higher.
The T1 uses a XHP50.2 though, a 7070 LED wont fit with the stock reflector.
rngwn
rngwn's picture
4000k is up for ordering and there’s quite an amount left. You can pick & choose the shipping method (in the other thread mentioned in the OP) then make payment.
0oklight
0oklight's picture
Thanks for this info thefreeman. I am right in thinking that you have modded a T1 with this LED? And if so, did you order the correct gasket separately?
thefreeman
No I have modded one with quad E21A but not this 7070 LED.
0oklight
0oklight's picture
Okay good to know. Will buy a T2 for the mod then.
id30209
id30209's picture
MoreLumens wrote:
Does anyone have beamshots comparing these to 219b's?
Oveready V4 with LuxRC engine (triple 219B sw40 by Azhu)
OR is on MAX 21W setting and T2 on HIGH (not Turbo)
Almost the same.
Here is evident why i’m constantly saying it’s 4500K-ish instead of 4000K. Smile
contactcr
Last seen: 4 days 6 hours ago
https://budgetlightforum.com/comment/1683441#comment-1683441
Definitely ~4500 in hot spot with reflector ^
id30209
id30209's picture
Yes!!!
Thx Curtis!
id30209
id30209's picture
MoreLumens wrote:
Ok thanks for pics and info, so 4000k would be closest match with sw45k?
Almost. No LED can match 219B
pol77
Last seen: 22 hours 32 min ago
Does anyone know of a suitable MCPCB and TIR to mod an Olight M2R Warrior Pro with this LED?
contactcr
They already come on a 12V mcpcb you could sand down (if needed) but finding a TIR that small with such a big LED opening is probably unobtanium.
pol77
I thought the TIR might be an issue. A pity though, I quite like the M2R Pro and I would love it with a good LED.
