WTS/GB: [4000k ARRIVED, Test Report's In] GT-FC40 (a.k.a. XHP70's flattop, 12v 40w sister) 95 CRI, Available in 4000k, 5000k
Definitely ~4500 in hot spot with reflector ^
Yes!!!
Thx Curtis!
Almost. No LED can match 219B
Does anyone know of a suitable MCPCB and TIR to mod an Olight M2R Warrior Pro with this LED?
They already come on a 12V mcpcb you could sand down (if needed) but finding a TIR that small with such a big LED opening is probably unobtanium.
I thought the TIR might be an issue. A pity though, I quite like the M2R Pro and I would love it with a good LED.
KD got a few 80 and 90 CRI XHP35’s but who knows how good they are.
I already put one of those 90 CRI ones in my M2R Pro. They are loads better than the original, but not as good as this LED.
Damn it. This just put the T2 on my wish list.
I’m wondering if there are any optics suitable for this emitter and other xhp35 lights like the M300 and Klarus E3. The E3 is particularly attractive to me in form factor as a slim 21700, deep carry, and tail switch design.
I sent Maukka 2pcs 4000k in the production batch for him to test, and here's the report for both pieces:
Summary: Slightly above BBL, but not wildly out of control. This report suggests that the stock I have is very different than the ones tested in the L6 FC-40 thread.
At 3 A: +0.0015/+0.0019
At 1A: +0.0023/+0.0026
Note: The sample is presumed to be tested without lens. Most AR-coated lens will bump the duv values by about +0.0020.
Where we can get datasheet? Thats from FC60 datasheet, but im pretty sure its the same because both rated same 12-14V.
I have my own FC-40 datasheet, but it's for the regular 70 CRI parts. The voltage curve should still be similar, though it's rather sketchy.
Okey, so you have datasheet, why just dont move it to the first post?
Does anyone know of a good 12V e-switch boost driver, like 25-26mm ish in size? I want to put one of these in an Astrolux FT02 XHP70.2 version, but the driver is dead and I can’t get one from Mateminco.
So, I can guess this GB never happened, didn’t it? :confused:
It partially did (for 4000k only).
Any leftover 4000K A4 bin for sale? I am interested…
The best tinted FC40 of all i've seen.
I have a bunch of it left, if you're interested.
Do you still have any of the 4000K a available? If so, would it be possible to ship to Canada? Thanks
