[Update]Wurkkos dual LEDs 21700 Headlamp design Photos/UI update~
344 posts / 0 new
Tom E
Tom E's picture
Last seen: 8 min 36 sec ago
Wurkkos wrote:
We are testing more and improving the reverse charging function, the first batch, no problem for charge flashlights, huawei phone, MI phone ,ect
Good to hear. We noticed it's showing no stock on the Ali store and Amazon now.
lux-Perpetua should have the full summary of manual changes for the UI, and list of bugs.
jetstorm
Last seen: 2 hours 23 min ago
Hey Wurkkos. I ordered the HD20 with the battery and it seems to have a flashing red during a 90 minute charge. The charge indicator never turned green. Via the manual it says the battery is critical so I tried swapping it out with another battery and the problem was not resolved. I ordered the light off AliExpress on 11.11.20. Any advice on this issue would be appreciated. Thanks.
SammysHP
SammysHP's picture
Last seen: 4 hours 46 min ago
During charging the indicator blinks red and switches to constant green when finished. Charging can take up to three or four hours.
jetstorm
My FC11 is a solid red when charging. I looked around and found info regarding the below. I don’t think my battery would still be below 3% after a hour charge. Also the other batteries tested were running well in other flashlights.
3% > Flashing Red
30% > Constant Red > 3%
Constant Green > 30%
Per this manual: https://drive.google.com/drive/folders/1MibSgwWIBUqBfb6VgZSPhusiyT7ZE_yH
Per these reviews:
https://budgetlightforum.com/node/74729
https://budgetlightforum.com/node/74979
SammysHP
SammysHP's picture
That’s the indicator when not charging. While charging it blinks red. Plug it in and wait four hours.
jetstorm
Ok. Thanks. Will give this a try.
Wurkkos
Wurkkos's picture
Last seen: 1 day 15 hours ago
We Tested discharge of HD20 again (batch 1#) different phone and products shows different discharge current, so different equipment will influence the reverse charging current.
Charging by 18W Adapter
HD20 Reverse charge the other HD20 1.67A
HD20 Reverse charge FC11 0.92A
HD20 Revere charge Phone#1 1.08A
HD20 Revere charge Phone#2 0.93A*
HD20 Revere charge Phone#3 0.46A
Wurkkos
Wurkkos's picture
Iphone can not be charged by batch#1, reverse charging current will update more stable from 1A-1.8A, and will compatible with Iphone for batch #2
Quadrupel
Quadrupel's picture
Last seen: 4 hours 20 min ago
Output voltage is to low. To charge phones at full power you need to keep about 5.2-5.3V .
will34
will34's picture
Last seen: 1 hour 7 min ago
The meter is placed at the end of the charging cable, I think 4.85-95V is fine.
Quadrupel
Quadrupel's picture
Sure, if you like slow charge Big Smile
Caleb
Caleb's picture
Last seen: 2 hours 17 min ago
Workkos, thank you for improving this unique light.
Is it possible to offer more LED options when this light is re-released? I believe several suggestions were made earlier in this thread.
mbp
Last seen: 4 hours 28 min ago
SST-20 4000k 95CRI for the throw LED PLEASE, would take this light to another level IMO, and Sofirn already uses them and should have stock.
