I suggested Sofirn to look for a Px flux bin and a DC or DD chromaticity bin of SST40, being around 4.800K. This one seems to please most of us, being quite neutralwhite and not greenish, see Wildtrail's BLF D80v2.
If I recall correctly from the SC31 Pro thread, Sofirn is definitely interested in SST40 4.000K but so far it is difficult for them to source.
Type C-C cable compatibility should be easy to achieve. Basically, it's just two additional resistors in the USB-C port to make it work. But even with USB-C (type C-C) it will still be using 5V 2A (10W) or maybe 12V 1.5A (18W) as we have seen it before in Sofirn's SP36S, see my picture below for reference. A powerbank mode ("reverse charging") would be great but my guess is that SP36 Pro will not come with that feature as it requires significant driver changes. But maybe we will be surprised... ;-) Since Wurkkos has introduced reverse charging with their new HD20 model, I am confident that Sofirn will eventually offer this functionality, too. I hope that future driver revisions will offer the PowerDelivery protocol with 36W (12V 3A) for faster recharging.
Nice! Guess I’ll possibly get myself another SC31 Pro in the future then
Yeah I was looking up info about type c - c and I might try to mod my SC31 Pro and/or make an adapter which adds resistors to “activate” 5V power on PD compliant chargers.
Cool! I did not know the SP36S had this functionality so I hope/assume they’ll add it to the SP36 Pro too!
Yeah I have the same feeling, and yes I was pleasantly surprised by this functionality of the HD20 which was one of the reasons why I ordered it. I kinda feel bad they didn’t include this functionality on the SC31 Pro though, since I carry this light everywhere with me in my backpack and powerbank functionality would save me some weight without also carrying a dedicated powerbank. I don’t see me carrying the HD20 everywhere.
Do you/anybody have any idea if powerbank functionality is also planned for a future revision of the LT1? Apart from the SP36 that’s another light I also want to get but might wait a little longer for a new version to come out…
If I got Barry right, the USB-C output "powerbank" feature for LT1 is being tested by Sofirn already. Let's hope we get to read some amazing news anytime soon. :-)
That’s awesome to hear! I’ll be sure to hold off buying an LT1 then for now, I won’t really need it anytime soon… Let’s hope I can buy it by the end of the year on Aliexpress because the import rules will change in the EU and buying directly from China will certainly get more difficult and/or expensive
Smooth ramp should be 3 clicks while on. Make sure your batteries are charged. Reset the light by holding the button and screwing the light back together. Are you familiar with Anduril the operating system?
Are you using anduril 1 or 2? To check, click 4x from off to lock the light. Click 4 times again. If the light stays off, it is Anduril , if it turns on, it is 2.
They are fairly different in their programming at first.
The Lumintop GT Nano is my only NarsilM light, so my experience with NarsilM is limited, but the behavior your Sofirn SP36 with NarsilM exhibits (whether normal or not) may be related to the NarsilM battery LVP (Low Voltage Protection) function.
The below quote is from forum member "Tom E" (who developed NarsilM):
Before and immediately after the blinking occurs, you could use the NarsilM (triple-click) "Battery Check" function to determine what voltage the light thinks the battery is at when this behavior occurs (and compare these values to the actual battery voltages as measured with an accurate external volt meter) to ensure that the LVP for your light is working correctly (assuming each of the three batteries in your SP36 functions adequately with acceptable battery internal resistances to provide the current necessary to sustain the selected output).
The LVP blink warnings and main LED output reductions should start occurring at about 3.0 V, with the main LED shutting off at about 2.8 V.
Also, be aware that the voltage for older or inferior batteries (even charged older or inferior batteries) can drop substantially when a load is applied to them (and their voltage can also quickly recover when the load is removed).
