New Year coupon HNY2021 for YLP Unicorn 1.0 (valid until 27.12.2020)
https://ylplight.com/en/katalog/1/ruchnye-fonari/unicorn-10/
Special price 2021 Russian rubles, or 26% discount if paid in dollars :+1:
Unicorn reviews:
Unicorn reviews:
Wow, thank you! Any news about the release date of the Gekko 1.0?
Does the code get you 26% off the normal price, or do you get an extra 26% off the code price if paying with dollars?
Yes, 26% off the normal price.
Any codes for the Panda 2M CRI? Please...
slmjim
Late January - early February.
Unfortunately, they do not currently offer discounts for Panda.
You can still use general BLF coupon for 10% discount.
Thanks for the info! Too bad it got delayed so long. Hoped to get it for Christmas.
That gekko’s a nice look
@fnksb
Back in 2019 we talked about the project under working name:Stark (2*21700 8*SST20 Hi CRI 4000K)
(YLP coupon for BLF - #87 by fnksb)
(More info and pictures here (Russian): Фонарик с тачскрином... | Мастерская: INFERION)
On below video someone is using a button on the other side of the flashlight to increase/decrease brightness.
Is that space on the left side of the touchscreen to control brightness? Or is it just an indicator?
This flashlight has one of the best design I have seen all time and has a huge potential for an amazing UI if they didn’t implement any gimmicky function, with 2 buttons the UI possibility are almost endless but I for one would love to keep it simple, one button operation with the touchscreen (if its really a touchscreen) to switch around different screens showing some instead of all the numbers.
I hope they don’t make the same mistakes as with the M43, amazing design and driver engineering, but overly complicated UI.
Gekko 1.0: Gekko 1.0 — Online store — YLP light
Coupon code: Gekko21 (valid until 02/23/2021)
Thanks. The cost in US dollars with the coupon code and shipping came out a lot lower than I expected based on the estimates on the website. Came out to $36 shipped rather than $36+7=$43 that I was expecting :+1: . I’ve been following the mega Fonarevka thread, and it didn’t take much for me to click buy.
Is the switch the same as the Unicorn ? The size looks similar but can’t know just from the pics. I didn’t like that it was too small and had a noisy click.
Before you buy, a quick summary of what I’ve understood via Google translate:
Overall I’m pretty disappointed by this light. The hardware seems decent for the price and Inferion made a very efficient and good firmware for the Unicorn. But with this release the firmware appears to be in a beta state at most. Too many bugs, not the expected features. I planned to buy at least one, maybe two or three. Now I will wait for an improved model. If YLP would allow firmware updates this would be different.
@thefreeman
The switch should be improved. Not so hard to press and bigger.
Thank you for taking the time to summarise all this. Well that’s disappointing.
Btw all my info is from https://translate.google.com/translate?hl=&sl=ru&tl=en&u=http%3A%2F%2Fforum.fonarevka.ru%2Fshowthread.php%3Ft%3D44328&sandbox=1
B
I probably jumped the gun a bit with my purchase and should have waited another week until a just before the coupon code expires before buying as people are just now receiving the light and giving assessments. However, at least for me, those deficiencies that you mention are not going to be a problem. I don’t use moonlight in the headlamp form factor - will be using mainly 300 lumens and up with active movement providing cooling, and in the cold (headlamp season equals cold season for me). The smooth thermal control and good efficiency were the main attractions, and I’m guessing from the description that the TIR will provide a good pattern for my type of usage. So I probably would have purchased this early version as a backup/alternative for my larger headlamp anyway.
That wasn’t hot glue under the star. That’s what (cheap) thermal paste often looks like. I have a tube of something similar looking or the same myself.
Yeah, seems like some cheap stuff. Meanwhile AEDe posted some photos of the inside of the head:
http://forum.fonarevka.ru/showpost.php?p=1330296&postcount=2573
http://forum.fonarevka.ru/showpost.php?p=1330301&postcount=2576
Problem is that the shelf is very thin and not flat, the center under the LED is slightly concave. The 1 mm thick MCPCB doesn’t even make contact with the shelf because it sits on the rims of the screw holes! The thermal design is a total failure.
For using it as a simple light at 200-300 lm it is OK. But I expected much more after the Unicorn.
The initial 900 lm are reduced to 300 lm after some minutes due to heat. Thermal regulation seems to be great, as expected from Inferion. 400 lm should be possible if temperature limit is set to 75 °C.
I should correct this. The main auditory for this light in Russia is not a flashaholic, but odinary user.
So
Anyway, user can try to change TK limit.
The driver has external flashing pads for updates, but YLP refuses to provide update files
Not. New firmware not finished yet, so YLP don’t discuss ability to reflash until readiness of new firmware.
They say you can’t expect more from a light that is this cheap. IMHO they should have set their goals lower
Only real expluatation wold show, if this flashlight is brilliant or not.
Anyway, by the low price any user takes from the box well built L-shape flashlight.
With direct current reglation, workable TK, comfort weight and HiCri lght.
