Sorry about the quality of the images, I don't have decent artificial lighting and now that I live in UK I'm bereft of quality daylight with a constant overcast sky day after day.....plus the rain, always raining....
I'm used to carrying a bog standard Aluminium D4V2, with stainless steel bezel and clip and used to its weight, this copper version makes it feel lighter than air.
Weighing in at 172.4g without a battery or clip installed, by comparison the aluminium D4V2 with S/S bezel, clip fitted and battery weighs 78.2g (with battery 125g)
Sadly there are a few issues with the flashlight not matching the lovely photo at the start of this thread with perfectly shiny machined surfaces, mine has surface blemishes where the shiny machined surface has patches of dull, sandblasted like surface finish. My example also came with scratches to the base of the tailcap. Not sure if its worth trying to deal with these issues given the time it took to get this into my hands, just disappointed it does not meet the typical standard I have come to expect from Hank. I will try to capture the blemishes but lacking in decent lighting and no natural light, will try tomorrow.
I just received another D4V2 in the 219C earlier this week. I know 219C has fallen out of favor a bit but I was hoping Hank got a nice tint bin, and my hopes were rewarded. His 219C 4000k quite rosy (not 219b sw45k level but looks very close to sw40), looks identical to the bin Lumintop uses, much nicer than any SST-20 or LH351D Iāve seen.
The only caveat is that 219C does not play nice in a smooth reflector or clear spot optic, it has a bit of a dark spot in the center of the beam when white wall hunting. You need to order it with 10623 optic, I did not but had one laying around and swapped in, fixed the problem.
Thatās a great looking light. You can do this with oven cleaner. It will remove the anodizing. I didnāt care for the sand color and used oven cleaner with good results. Unfortunately I had already mechanically removed the anodizing in some areas, and that didnāt turn out so great. If you have access to a lathe you could easily modify the knurled area like that too. :sunglasses:
My first version aluminum D4 lights donāt have the same threads as my D4V2 Ti. Does anyone know if the aluminum D4V2 threads are the same as the D4V2 Ti?
Got mine about 4 days ago. 3 weeks from order to delivery. Canāt complain about that really. I usually expect 4 to 6 weeks.
Only complaint I have? Itās really really really really, heavy. Even with the 350 tube on it, itās really heavy. Donāt know what I was thinking. It was so good looking, my finger couldnāt help but hit the buy button.
The 4000k 219Cās look really nice and of course it operates perfectly and is very well built. I donāt know what to do with it. Too heavy to carry and Iām not much on collecting shelf queens. Itās back in the box for now.
They do look good and agreed, very very heavy. Funny thing is, I thought the aluminium D4V2 was reasonably heavy but now I have a renewed appreciation for itās low mass in the pocket properties.
Despite its weight Iāve been using the copper D4V2 on dog walks, with it being winter here in UK I appreciate the hand warmer and extended runtime of the copper thermal properties.
I have since put a forced patina on mine using the hard boiled eggs method.
I have been carrying the brass d4v2 all day, everyday for about a month now, since i got it. I donāt know how much heavier the copper is, but ill buy it off you.
EDIT - What emitters does it have? - i see its 4000k nichia 219c
