The There Are No Stupid Questions Thread
Thanks Robin Dobbie and JasonWW for your replies.
That seems a good way to calculate that!
These are all estimations of course, but I was wondering how much lumens it would produce.
That is a Convoy S6 I did with a FET driver from Lexel w/ Bistro HD OTSM, 3 Luxeon V installed in an led4power alluramic MCPCB, spring bypassed, copper spacer from kiriba-ru, forward clicky switch and Carclo 10511.
That thing gets HOT real quick anf puts out a small wall of light, so I was wondering how much it would be putting with that Amp draw (which will be different when using the switch and not the thick copper cable I used).
Thanks again for the replies!
At thefreeman, I went to a local store and got a relatively thick cable (4mm outter diameter), made of copper inner strands thicker than AWG inner strands.
It will work :smiley:
We don’t know what led you’re using. Different bins and color temperatures have different outputs.
So like Robin said earlier:
Maybe 4500lm if it’s CW
Maybe 3900lm if it’s WW
You might lose some amperage when you put the tailcap on and that will lower output slightly.
TIR efficiency varies, but I’d say its close to reflectors in general.
I think it was djozz? Had 4x Luxeon V in a D4 (I do, too) and measured over 5000 lumens at turn-on.
I can’t measure the current or lumens on my D4 though.
My question is, ‘Can a lighted switch be hooked up to this driver ? It will need power, I do not know where or the voltage to hook the leds too.’
This is for the 2020 BLF O-L contest build, so any help is awesome :smiley:
You can answer here if you wish … #47CNCman's entry to the 8th annual BLF/O-L contest [ Handmade - FINISHED - ]
I do have a question about a “MTN 12mm Momentary Switch (for momentary / e.switch drivers)”
http://www.mtnelectronics.com/index.php?route=product/product&path=25_83…
The driver i’m using to hook it to is,
http://www.mtnelectronics.com/index.php?route=product/product&path=67&pr…
I have and understand the instructions where the 2 wires go for controlling the driver.
I have the non-led switches in hand and just ordered some with led.
Here are the options for the driver below.
FET Driver – 20mm model FET20-SS – Zener Mod?: Yes – ~6V LVP – Firmware: Electronic Switch CU… – Turbo Timer: 120 Seconds
Electronic Switch CUSTOM Firmware Options.
1. Number of light levels: 4
2. Approximate PWM levels of each mode: (1) 10% – (2) 30% – (3) 60% – (4) – 100%
Zener Mod: Yes – ~6V LVP
This question is like asking if I can add a horn to this specific model car. It doesn’t matter the year, make or model. It can be done. You just need some DC power.
You can tap a power wire into the middle of the driver where the red led wire is soldered. That’s battery power before the main led.
It looks like your switch has an on board location for a resistor. That’s good. It should use the same ground wire as the switch circuit.
So you’ll just need to add the one extra wire and resistor. Probably a 15k to 50k resistor. All very easy.
You can see how I added a switch led wire to my L6 here. I had to add an inline resistor, though.
It will draw power whenever the tail switch is on, but I don’t think that is a problem for you.
Thank You JasonWW :+1:
I am setting up a 2S or 6-8V configuration. Does it matter the voltage going into the switch ?
As far as the colored leds are concerned, the resistor will drop the voltage way down to within their normal range. Without a resistor it would blow right away.
There are many different smd leds with all types of specs. Specs even change within the same model, but different color. This is why you need to experiment with resistor values. Start around 15k-30k. See what the brightness is. I think I’ve even had to go up to 100k on one of my lights due to the color and it’s high current draw.
If it were a 3 volt source I’d say start between 7k and 15k. With 6v you basically double the resistance, hence 15k to 30k.
Here is the info from MTN Electronics.
So your saying I should start with the 36K since using 2S and stack more to lower brightness ?
It comes with 2 leds installed.
Connection Points / Bridge Points:
Because this switch was designed to be as versatile as possible, there are several different connection points and possible configurations.
Switch Connections: SW+ & SW- GND (SW- is ground).
LED Connections:
If connecting directly to Batt+ or from an MCU output: LED+ & bridge “LED- GND BRIDG.”
If switching from a negative side (such as a MOSFET): LED- & LED+. Do not bridge anything.
LED Option:
Optionally, you may have two color or white LEDs pre-installed on the switch, which are often used as indicator lights.
Three SMD 0603 resistors will come included, but not installed (4.7K, 19.1K & 36K). You can try different resistor combinations depending on your input voltage and desired LED brightness. We recommend that you start with 36K—-you can then swap or stack more resistors to increase the current from there. It is not recommended to go above a few mA of current to these small LEDs. The lower the total resistance value, the brighter the LEDs will be.
OK , I see, your L6 is a S2 configuration.
Thank You very much JasonWW :smiley:
The switches will come in Monday and I will experiment at that time :+1:
And I’m sorry for not understanding your earlier post, Grand kids are here distracting me :person_facepalming:
And start with the 19K resistor first. :+1:
I’d start with the 36k.
Stacking resistors reduces resistance and makes it brighter. Higher resistance makes it dimmer.
To go above 36k you need to add another resistor in series. Sometimes you can stack them like this /\ to squeeze 2 resistors on a single pad. The proper way is to swap to a higher resistance resistor.
36k should be fine, it might be brighter than you want, but should work. If you want to dim it you can order some more resistors from ebay. I see MTNE sells a 69k resistor. If you haven’t ordered the switch yet you can have him add some of those. Otherwise, you can order an assortment on ebay. Shipping may take a while, but they are cheap. It’s handy to have an assortment on hand. You can also order an assortment of smd leds as well. It’s fun to mix and match colors.
Thank you very much Jason for explaining that so clearly for me. :smiley:
I wanted to order some in the past, but its confusing what size and resistance range to order.
I will try again.
:+1:
If you wanted, that driver could likely be flashed with Anduril, in which case you could probably get one of pins 5/6/7 for the switch LED (likely one controls the FET and the others are unused). But that would take a bit of doing…
I was looking through the details of that driver and I noticed Richard does not recommend the zener mod in a 2s design.
“Not recommended for use with the Zener Mod option. For 2S+ cell momentary use, check out the LDO 20mm driver instead.”
What are the best resources on building a Convoy? I’ve seen a couple videos.
Can I build a Convoy S21B quad, which requires a 20 mm MCPCB and 22 mm driver?
What would be a good driver, board, and optic?
What sizes of LED would such an optic limit me to?
Lumileds Luxeon are reportedly very efficient. Opinions on this brand?
Yep you are correct. :+1:
I looked at the reason and he said the parasitic drain was bad on this driver and a momentary switch used with batteries left in the light would drain the batteries quickly. I thought it will work, and the tail cap switch should control the parasitic drain. The reason for trying to get the lighted momentary switch hooked up, is to know the light is powered up. When not in use, just make sure the momentary switch light is off by clicking off at the tail cap. I may have overlooked something here because electronics are still a very weak area for me, so let me know. :question:
I wanted to use the LDO 20mm driver at first, but they were out of stock.
I do have a backup driver that uses just the tail cap switch if needed.
https://asflashlights.com/-diy-parts/75-10-amp-capable-17mm-led-driver.html
Is swapping the LEDs of a Convoy S2 UV and an S2+ with a more powerful driver a bad idea?
The UV leds can’t take much power so don’t mess with those.
What led does the S2 have?
im selling something i bought on amazon in a second hand market, the buyer is asking for the gift receipt. is there anything i should be concerned about? like is there anything they can do with the gift receipt that can be linked back to me in a negative way?
You may get some thicker PCB and file them down to the desired thickness.
It’s a bit painful with copper, so for people who have them I’d recommend some Virence / Led4Power alu PCBs. These are hard to get nowadays though…
It never produced much heat so I figured it wasn’t being worked hard.
According to the description on Banggood:
  • LG UV365nm LED 5W lamp beads are used.
  • The built-in drive is 7135x5 single file.
