So thats why the little gnats fly around my headlamps at night. Yeah we are 70 miles from the Canadian border. I see the entire milky way and satellites flying over. Even see the solar particles interacting with the magnetic field.
So deep red is a better choice?
Any headlamps come with deep red/white combo? Low 1 lumen red and direct red from off UI?
I have a nitecore Nu17, I bought it to use during a 2 week grand canyon trip. Didnât need it a ton, as when it was dark I slept. Red light on low is great for near objects, red light on high makes walking around camp at night easy. Best part was lack of bugs when using the red light vs white. I picked up two on sale somewhere for less than $20 each. Good deal, only downside could be built in battery which makes you throw away the light when the battery dies.
I can see like a cat at night, and keep most lights off (not even nightlights), so yeah, I know how little light I actually need to see where Iâm going.
Still, if the main objective is runtime, for the same visible light, youâd be able to minimise current and stretch runtime with regular-red.
Anduril 2 will have features hidden more but you can use yours according to your suggestions already.
If you set memory mode to your favorite âmidâ level that will give you 1 click to mid, push hold to low, double press to high.
Donât level up your clicker hero skills on the power button and the other modes stay hidden.
I guess anduril-roid 2 is the firmware? Can I upload that version to mine when it comes out or does it mean a whole new lantern? Sorry I didnt read all 12,000 pages of the lantern thread (yikes).
Can I bore the lights out and drop in 4x21700? Could I make a 4x21700 battery holder and plug into charge port for extended run-times?
Yes and yes, youâll need some parts to change the FW though.
No, I think its unlikely you could get 4x21700 to line up with the brass ring where the positive terminal would be. So yes, it would be much easier to plug in a power bank to the USB C charge port and get extended run-times. Could be 4x21700, 40x21700, or anything else that provides roughly 5V. And no, see the previous response regarding the positive terminal aligning with the brass ring. You could do some measuring and math to see if it might be possible and let us know.
3 21700s might work, but the LT1 is already on the edge of being too big to be useful in my opinion. You could easily supplement the run time with something like a XTAR PB2S loaded with 21700s. Plug it in for an extra ~10,000 mAH, and recharge when necessary. You could even recharge both at one time, leave the PB2S plugged into the lantern, and connect the charger to the PB2S. It will charge all the batteries at the same time. I havenât tried that, but I think I will tonight to see how well the lantern runs while hooked up that way.
Going from 3500mah 18650s to 5000mah 21700s means going from one day to just under a day and a half, you wonât get a week. The lantern does run off the USB port though without any 18650s installed so you can run it off 5v USB batteries though you wonât get full power that way as the USB input is current limited. (I think to 1.5A so still very usable).
Iâm glad someone else pointed out that the lantern is already programmable yet simple in use as you wanted, you donât have to access all the extra features, set the mode you want and itâs a simple on/off to that mode every time (with shortcuts to low and max as mentioned).
I donât want to knock your enthusiasm but i find it strange youâre offering suggestions for improvement without actually knowing how they work.
Yep you are correct. I thought i had watched enough videos on operation and read the info to know how it worked. My bad!
I have the lantern in my hands now. Its an amazing light. Very nicely done!
The only thing I see that would improve the light are making orange button flash battery voltage instead of main light. Also when I changed the 3000mah batteries it came with to 3450mah it made screwing the lower body onto the top difficult. The bigger batteries are longer and stick up just enough so that you have to compress all 4 batteries under spring pressure while not cross theading body to base. I also worried about concaving longer batteties under so much compression, which I have done before in other lights.
Back to the 21700 batteries. One half day extra runtime would add 3 more nights of running. We use it 4hrs per night.
We ran it 4hrs last night. Battry v went from 4.2 to 4.11 with all 4 being exactly the same. I am impressed! My feniix lantern would have drained the batteries 50% and all 3 would have different voltages.
I will report back again with how long it runs for us.
I have the tint ramp set to neutral white on high and warm white on low. Just an amazing light. I wish I would have bought it sooner
[quote=idahofarmer]
/quote]
Idahofarmer, do you happen to have another powersource besides 18650 batteries? maybe AGM batteries etcâŚ
I also think you could plug in your LT1 into a charger, DBSAR mentions that it could handle 5V-70V
Check his video at around 7:40 pretty cool solution:
I have no value to add to this conversation - but i just want to say thank you to everyone chipping in here! I have learned valuable info about why i may want a good lantern on 18650 for my camp trips, and the value of red light. love this forum. learning a little everyday.
+1 for simple UI. Seeing how friends and family have reacted to the Anduril UI has convinced me not to buy more as gifts. Current muggle mode has its issues IMO.
As soon as they can get Anduril 2.0 in the new batch of LT1, or even an LT1 Simple Edition, Iâll be buying a lot more. I would really like to see something with a dimmer knob (like a car stereoâ push knob to turn on/off/other functions, rotate knob to adjust brightness.)
Reporting back after 2nd night of use. Battery meter is saying 4 long one short meaning 4.0v after 2 nights running. The fenix would be dead at this point. If this drain holds true this thing should go 10 nights running. I will report back tomorrow with voltage.
Also the days are getting shorter here in N Idaho so usage will go up.
Lawnmower batteries? Are these deep cycle type? I say this because, if going lead-acid, one must be specially careful with them. They don't tolerate well being discharged, particularly starter batteries which can get killed with just a few deep discharges. Deep cycle types do well until half depth, or so they say.
A stationary li-ion, or better, LiFePO4 battery does a better job in these regards, in my opinion. If there's need, of course.
yes, sealed lawnmower batteries from my 10 year old lawnmower that couldnât make it around the yard anymore. I purchased a new set and used the old ones in my solar setup. If I kill them then Iâll move onto another plan, but most days they are charged with .3A, and only are used at night at .05A. New they were each 10AHr, so I donât think Iâll be over discharging them soon. But thanks for the warning.
I love this thread, I agree with the first post!
Requires a âsillyâ firmware. I like the simple UI.
Everyone loves and understands the simple UI.
I wrote an article in the past about several Narsil M firmware flashlights and got a bunch of emails on what works. I wrote, I drew, I made a full description in Hungarian, but people donât understand it.
Thanks for the information on the Fenix CL30R lantern, I planned to get one, but now I stopped a bit. Still, wouldnât it be as good as it looks?
Many people requires a long runtime âemergencyâ lantern. I just bought a kerosene lantern too, because if all the batteries are completely discharged and there is no sunlight the solar cell is worth nothing. Kerosene is âromanticâ but can be less effective and more dangerous.
