Some reflection on this mod!
Well, the most difficult thing was to have an idea that would be feasible given the conditions (materials/tools/skills) I currently have!
After a while thinking of what could be done, from Friday to Saturday I had this idea and decided to give it a go!
Unfortunately I didn’t realize soon that the pill was not possible to use in the hand made category, but that didn’t demove me from doing it!
So I kept the project while seeing the replies on the competition thread.
The greatest difficulties I had, at least initially, was how to hold things together internally, as I didn’t want to and couldn’t use many screws, due to the wood thickness.
Then I realized hot glue could be a good solution. I even thought I would use silicone, but it doesn’t dry as fast as the glue!
It was still a messy job when pouring it into the “sandwich” but I managed to just burn the fingers for some occasions
Another difficulty was when the battery contacts where moving and I needed to press them and melt some more glue, to make the heat reach further allowing to move them inwards again
The bottom (door) of the flashlight was also somethin that was a bit mind blowing, before reaching the solution, I mean! I was thinking of putting leather, of a piece shapped of hot glue, but that wouldn’t work well :zipper_mouth_face: So, the solution I reached was a good compromise I guess. Too bad that this part is not “waterproof” but…the WooDJewl is made of wood, so…
The most challening things I faced while conceiving it were related to the pill and the disposition of the cables, switch and pill. When I decided that I was going to use an AA battery instead of a LR1, that made my decisions more steady. I still feel that I could add something more inside, but this will to the job!
I also would like to put a lanyard on it, but that probably won’t happen once I won’t make more holes on the light! I could eventually add a hook on it or some magents but…it will stay this way
I had lot of fun, despite all the cursing I said, because this was the firts from scratch mod I did: I modded wood plates into a flashlight
Despite being a small mod, if compared to many others on the forum, I feel proud for it
I wanna thank all the encouragement words and support on this
And to all the contestants, good luck and good work! It is always great to learn from you
