personal code in email, probably sent to people that ordered before.
I spoke with Jack and he said I would get one too but still haven’t seen it yet. Was it a generic code that’s seemed like everyone can use was it a personalized one? Thanks for responding.
I have ordered flashlights from FireFlies directly before, but did not received a coupon yet. Maybe these codes are sent out manually, so I hope, that I will also get coupon(s).
With the coupon price, I would be interested in one 4500K.
EDIT: I got coupon on 8th December, thanks very much - preordered
Why are the new FF lights only rated IP65? I get that these are novelty lights, but most other manufacturers are able to build properly waterproof lights. I find this a bit disappointing to be honest, also given the price points.
Single tint version is also very good for many uses, but I can agree, that a variant with ToyKeeper’s tint mixing UI could be another highlight product for FireFlies.
I’d personally suggest these changes (product idea for a lantern):
- adding 3500K to the tint choices
- making the tint mixing between 2000K and 3500K - this could make it extra moody, and mixed tints would not be too rosy (staying close to the BBL is better, extreme negative duv values are similarly unattractive like significantly positive duv values).
- adding a trapezoid thread to the flashlight bezel on the outer side, and making a diffusor (including a mirror-like element on its inner top side to redistribute light more horizontally), which could be screwed onto the flashlight head using that thread.
keeping the compatibility with the current battery tube, but also letting usage of a newly designed 3×21700 battery tube (batteries should be contacted well, even if they are flat tops - double spring on the bottom and separate metal disc contacts /with at least 6mm diameter/ on top)
The 3×21700 battery tube and the screw-on diffusor could make this flashlight into an even better than BLF LT1 lantern.
