I just received another D4V2 in the 219C earlier this week. I know 219C has fallen out of favor a bit but I was hoping Hank got a nice tint bin, and my hopes were rewarded. His 219C 4000k quite rosy (not 219b sw45k level but looks very close to sw40), looks identical to the bin Lumintop uses, much nicer than any SST-20 or LH351D I’ve seen.
The only caveat is that 219C does not play nice in a smooth reflector or clear spot optic, it has a bit of a dark spot in the center of the beam when white wall hunting. You need to order it with 10623 optic, I did not but had one laying around and swapped in, fixed the problem.
That’s a great looking light. You can do this with oven cleaner. It will remove the anodizing. I didn’t care for the sand color and used oven cleaner with good results. Unfortunately I had already mechanically removed the anodizing in some areas, and that didn’t turn out so great. If you have access to a lathe you could easily modify the knurled area like that too. :sunglasses:
My first version aluminum D4 lights don’t have the same threads as my D4V2 Ti. Does anyone know if the aluminum D4V2 threads are the same as the D4V2 Ti?
Got mine about 4 days ago. 3 weeks from order to delivery. Can’t complain about that really. I usually expect 4 to 6 weeks.
Only complaint I have? It’s really really really really, heavy. Even with the 350 tube on it, it’s really heavy. Don’t know what I was thinking. It was so good looking, my finger couldn’t help but hit the buy button.
The 4000k 219C’s look really nice and of course it operates perfectly and is very well built. I don’t know what to do with it. Too heavy to carry and I’m not much on collecting shelf queens. It’s back in the box for now.
They do look good and agreed, very very heavy. Funny thing is, I thought the aluminium D4V2 was reasonably heavy but now I have a renewed appreciation for it’s low mass in the pocket properties.
Despite its weight I’ve been using the copper D4V2 on dog walks, with it being winter here in UK I appreciate the hand warmer and extended runtime of the copper thermal properties.
I have since put a forced patina on mine using the hard boiled eggs method.
I have been carrying the brass d4v2 all day, everyday for about a month now, since i got it. I don’t know how much heavier the copper is, but ill buy it off you.
EDIT - What emitters does it have? - i see its 4000k nichia 219c
What is the correct version of Anduril (or Anduril 2) for D4V2 with E21A? Is it going to be the one for KR4 with nofet? If I remember correctly, both KR4 and D4V2 with E21A have the same driver (linear with 5A max).
