Test/review of Charger Olight UC
Charger Olight UC
Olight has made a very simple charger with no slots, but only magnets for battery connections. This is nothing new, except Olight has improved it significantly: Both LiIon and NiMH and no polarity.
The pack is very simple and contains only the charger.
The clear plastic around the wire has a red and green led behind it. This means it will be read while charging and green when done. The led will flash slowly red when not connection to any battery (Both with open and shorted connections).
The leds are fairly weak.
In this block the wire split into two, one for each end of the battery.
The two magnets.
Here the magnets are connected to a battery.
Only limit on battery size is charge current.
The current is a bit high for small cells, but some 14500 and 16340 will be acceptable because the current drops when voltage increase.
Measurements
  • Will discharge a LiIon battery with 1.1mA or 0.7mA (Depending on direction) when not powered
  • Will discharge a NiMH battery with 0.3mA or 0.2mA (Depending on direction) when not powered
  • Will charge a LiIon with 0.1mA with 4mA pulses when charging is finished.
  • Below 1 volt it will charge/discharge with 4mA
  • Between 1V and 1.7V the charger assumes NiMH
  • Between 1.7V and 3V it assumes LiIon and it will slow charge (0.3A)
  • Above 3V it will charge with full current
  • The charger will not restart if the voltage drops.
The charger uses CC/CV charging, but cannot deliver full current when the battery voltage is above 3.9V, termination is at 100mA.
This is a good charge curve.
This cell has higher charge voltage and the current will be a bit below maximum current.
Works fine.
This cell is old, again the charge voltage is high and the current drops a bit.
On paper the charger current is too high for these cells, but in praxis it is not that bad. A new cell would be charged with too high current at the start of charge and this is the time where the battery can best tolerate it.
Here I have added a 0.5ohm resistor in series with the usb power to simulate a long cable or weak usb charger. The charger do not handle that well, it terminates at 4.1V and 400mA.
M1: 33,2°C, M2: 25,7°C, HS1: 43,0°C
The charger get a bit warm and the battery stays cool.
It takes a few second for the charger to initialize a LiIon charge.
NiMH batteries
The charger uses voltage detection for NiMH batteries and not any significant top-off or trickle charge. This means the batteries will be slightly below a full charge.
The charge current for NiMH is 500mA
The eneloopPro and powerex are handled fine.
The charger cannot handle my old worn out eneloopXX (This battery is not really useable anymore).
The AAA cell is handled fine.
With voltage termination the charger is fairly fast at detecting a full cell
M1: 35,7°C, M2: 26,0°C, HS1: 47,5°C
The charger get a bit warm, but the battery stays cool.
The power on sequence is a bit long when charging NiMH.
The charger is fairly fast to get into the precharge phase, but there are some strange pulses.
I do not know the reason for these pulses, they do both look the same. They do not prevent the charger from trying to charge alkaline cells.
As usual for a NiMH the current will be turned off when checking voltage.
Conclusion
This is a very compact usb charger and it is fairly useful for many cells, it works best with a good stable usb power.
Because the charger is isolated from the cells it will never heat them. I like the automatic polarity, but I would have like the charge indication leds to be a lot brighter.
I will call it a good charger and the best I have seen of this type (usb with magnetic clamps).
Notes
thank you for the review. Amazing charger for the next vacation or business trip.
Thanks for the review, was waiting for this!
Seems like a great travel charger, and would be even better if charge rate was a bit higher.
Charge rate can always be discussed. Usb has some current limits:
0.5A Standard current from a computer
0.9A Current from a computer with usb 3
1A Typical older charger or simple phone chargers.
2A or more: Many new chargers.
Looking at the table I believe 0.8A is a nice value.
Another way to go would be a switch on the charger that could select between 0.5A and 1.5A, it would make the charger more complicated, but also more versatile and faster (To really use 1.5A the circuit and cable would have to be optimized a bit).
Thank you HKJ
This looks like something that would go well into a “bug out bag”.
Anyone knows where to buy it for less than 10$ ?
Fasttech for $ 9.99
And I think you can use the code BLF to save 5%
Amazon might be an option. In germany it’s 9,99€ including shipping for prime members. In France it’s 9,99€ + 1,99€ for shipping.
Thanks for the info, I saw it on Amazon but found it on ebay.fr without shipping fees.
So I bought it for 9,99€ free shipping and it comes from France so might be here in a few days.
I'm impressed. If not for the cable lenght, I'd have said “What the h1ll are those USB headphones?”. LoL!
Cheers ^:)
Any clue on how good can be this charger for a 21700 5000mAh cell?
I mean, for an “emergency” or travel situation, as example.
Or are there any better solutions in this format out there?
I am using it exatly for this purpose, and its works, its not very fast, but battery will be charged without any problems
Thank you very much for your input :wink:
I’ve been thinking about getting one of these, but was in the doubt because of the high capacity cells!
I think I will get one now :wink:
