Not enough time to get it to you, But next time you need a template, let me know and I will make one for you.
Free, of course
Great Work on your build :+1:
That would make it so much easier for accuracy, do you make the tempate from sheet metal? Im all ears the 2 I have done are not exactly right. Here is a photo of one tuned for a w30 engine that is just cut and polished the cut marks are visible.
This is the comp lights primary the mistake is obvious
The drum and bezel are done I will post some photos soon.
Original I wanted to use 170mm borosilicate 3d printer bases for a lens. For the secondary mirror mount I needed a hole so I ordered 5 and broke 4 so I am resorting to PMMA acrylic sheet. I should have that done tonight. This is the expensive blunder.
Probably .125 aluminum sheet. I can bevel one side to a sharp edge or a .030 flat.
I need the radius. It will be milled on a cnc.
That is really beautiful work !
CNCman the only problem is that with a parabola and hyperbola there is no actual radius. So to get one cut with a water jet or machined I am not exactly sure how I get the formula to program the machine. The reason being I worked out how to draw them without using a formula just a compass and ruler.
howdy grin, there are some really cool tools available on the wwwebsticle which can generate the equation or coordinates for your curves. If you wanted to post up a picture of a template curve then we could convert it to g-code, probably CNCman already knows all this too.
Some ray traces:
Kennybobby here are some detailed drawings of the plotted curves the grid paper is 1mm the drawing is full scale. I will take on CNCmans suggestion and make some templates to check the HSS profiles. The primary has a bandwidth of approximately 160° which is perfect for a 3mmx3mm led so maybe there might be some interest in a group buy of a 150mm parabolic reflector. The equation would have to be generated for that diameter and bandwidth.
Wow, your work is just amazing! I can't wait to see this light in action!
Thanks Zandar. It is getting closer but it looks like there has been very very little progress so there is not much to look at. It will be interesting to see how it works, I have been wondering if a collimated beam could be used because of the diverging secondary. The difference in beam with the led in front compared to behind.
Do you want the primary to be a parabola or hyperbola curve?
It looks like the secondary was drawn with a constant radius, did you want a circular section or ellipse/parabola/hyperbola for that?
I am using a hyperbola for the secondary. These are screen shots from an PDF I found on designing an antenna. I have used this info to plot the geometry and built the light to those dimensions and I pretty much need the light finished to seenif it works them make adjustments, sorry about the 2 resolutions i have chopped the original screen shot.
I will talk to our programmer and see if he can do this.
I’m not sure there is enough info, or better said, I have never programmed that before.
Our software may not generate that profile, I just don’t know yet.
I will try to draw that up on a 2D cad pgm at home first.
CNCman if you could machine prototype mirrors from a ray simulator then the loses from obstructions could be engineered out of the beam. One thing with led recoil is the most intense light is either lost through the centre hole or bounced back on itself. So should a secondary mirror should direct that light to where you want it most?
Nearly got the internals of the light engine done when. There was some very loud bangs and flashes out the front of the house. When I went to look I realised why the lathe had only half it power the old incoming mains was shorting out. It is a rental property but the owner is very casual so I thought I would upgrade the incoming cables and switchboard so I can run 20kw smelting furnace so I can turn all my swarf back into billets.
I’m interested in seeing this if you have any pics or comments
Only ~ 2 weeks left buddy. Hope it’s enough time for you
I think the aliens finally came and beamed him up for disturbing their flight paths. Either that or he’s recovering after a week long amber nectar binge! (or he could just be doing this 24/7 lol)
Grin……. what happened? Hope everything is ok. Whatever happens, please finish this
It is always a bit concerning when regular members disappear for long times, especially at the moment - I hope you are ok.
Yeah, his “last seen” matches his most recent post in this thread. I hope he is alright.
