Test/review of Shockli 14500 AA 1000mAh (Black)
64 posts / 0 new
TexasToasted
TexasToasted's picture
Last seen: 2 hours 31 min ago
These batteries fixed the erratic behavior in my Manker T02. That light is picky about battery internal resistance and voltage drop. Even the gold Vapcell 1000mAh cells had issues in that light.
MiG0
Any chance these nice batteries will pop up on Banggood soon?
Banggood is capable to send batteries to much more countries than Gearbest.
SKV89
Last seen: 6 days 40 min ago
Here are my test results:
Discharge capacity tested on a Xtar Dragon VP4 Plus:
Vapcell 1000mah gold – 993, 995 mah
Orbtronic 1000mah protected – 990, 972, 967 mah
Shockli 1000mah button top – 957, 921, 947, 950 mah
Shockli 1000mah flat top – 889 mah
Lumen on direct drive (highest output) tested with Texas Ace Lumen Sphere calibrated with Maukka lights:
GT Micro XP-L HI 4000K
(flat top no contact) Sanyo UR14500P 840mAh Battery
(flat top no contact) Vapcell 1000mah gold
964 lumens -14500 KeepPower 840mAh Sanyo UR14500P Protected Button Top
951 lumens – EVVA Protected Button Top 800mah
974 lumens – Orbtronic 1000mah protected button top
1194 lumens – Windyfire 600mah button top
1195 lumens – Shockli 1000mah button top
1155 lumens – Shockli 1000mah flat top
Kronos X5
903 lumens – Sanyo UR14500P 840mAh Battery
1110 lumens – Windyfire 600mah button top
1104 lumens – Shockli 1000mah button top
1086 lumens – Shockli 1000mah flat top
842 lumens – Orbtronic 1000mah protected button top
931 lumens – Vapcell 1000mah gold
Edited to include the Vapcell in the X5 testing. Seems like the Orbtronic uses the same cell as the Vacell and that they used an extremely high quality protection circuit because the output on the X5 is about the same between the two Orbtronic and Vapcell. The Shockli 1000mah is definitely the new king of 14500. It is both a high drain and high capacity cell, which is just incredible! However, the Vapcell and Orbtronic still has its uses because in lower power regulated lights, you won’t gain any lumens by using high drain cells and the Vapcell and Orbtronic is still the highest capacity 14500 by a small margin in low amp modes that would give you a bit more run time.
The release of the Shockli 1000mah just made 14500 flashlights much more interesting!
Shockli-Simon
Shockli-Simon's picture
GT Mini XP-L HI 4000K
Kronos X5
842 lumens Orbtronic 1000mah protected button top
Hi SKV89
I am glad you had received the battery, thanks for your feedback.
Some give away to BLF member(Only ship to USA, can not ship to other address)
thank BLF member’s support, Our company provide some give away to thank BLF member(USA), The give away product now only in stock in the United States amazon , so only available for USA address , please check the following give away product (you can choose a product, leave message or email sales@shockli.com to me, quantity is very little quantity)
NOTE: 1)Detailed product information can be confirmed by searching amazon in the United States 2)Ship Time : It will take 20-25day to reach USA
If you need a product, please copy the following and reduce the quantity of the product by 1, so that you can tell how many give away are still available
Shockli 14430 LIFEPO4 Battery( for solar light)—3pack
shockli 14500 LIFEPO4 Battery( for solar light)—1pack
shockli CR2 Battery( for smoke detectors, Range Finder)—2pack
GARMIN Cycling Bicycle Mount—3pack
08/06/2019—shockli-simon
Anthony Nguyenn
Anthony Nguyenn's picture
Thank you, Simon,
I ordered mine from AExpress and been using it for 2 weeks on my Lumintop AA 2.0.
Such a wonderful brightness and the best thing is its high capacity.
Thank you for this BLF giveaway
I just inbox you and picked the:
GARMIN Cycling Bicycle Mount 3 pack—> 2pack
Lumintop Tool AA 2.0 Nichia + CW| Lumintop Tool AAA | Lumintop EDC 18 6500k| Lumintop EDC 01| Convoy S2+ 7135*8 5000k | Convoy S2 UV Nichia |Massdrop Vega AA NW |BLF A6 NW | Nitecore Tube 2.0 | Sofirn SD 05 | Sofirn 01S 4000k| Klaurus G15 | Klarus HR1 Pro | Thrunite T10T v2 NW| Thrunite T1 Black + OD Green | Thrunite Ti3 CW+ NW| |Rovyvon A3x Nichia | Rovyvon A5x Cree | Rovyvon A23 Nichia | Wuben E19 Nichia | MecArmy SGN 6 | Wowtac BSS V4 | Wowtac W1 | Wowtac H01 | Ultratac A3N Nichia | Wurkkos FC11 |  Wurkkos WK30
Thrunite T2 |
LightObsession
Last seen: 1 week 1 day ago
Hi Simon,
If I’m eligible for the give away, I’d like the GARMIN Cycling Bicycle Mount 2 pack—> 1pack
Thank you very much.
Ventsi
Last seen: 2 days 13 hours ago
Anybody knows what are the cells inside the Shockli and Vapcell?
Just curious why only a few brands are selling good quality 14500 and none of them is the actual producer.
Paul321
Paul321's picture
Last seen: 3 weeks 17 hours ago
Though a friend on Amazon I ordered the four cell button top pack. The cells arrived with 3.89 – 3.9 volt charge, I did sample one cell with my Opus charger. The cell when fully charged has a capacity at 925 mah, wonderful. I don’t know of any other high capacity 14500 cells on the market. Much better than “name brand” (NC and XTR) cells I bought in the past. For lots more too! I use these cells in my JetBeam E10R, Skilhunt H15, AceBeam H40, and Thorfire TG06S. they fit and operate as expected. A great purchase.
BTW when I opened the shipping box an extra flat top 1000 mah 14500 was included.! Thanks Simon
Paul-
Shockli-Simon
Shockli 14500 1000mAh coupon code in aliexpress
Dear BLF numbers,
Thanks for your support of Shockli brand, Now we are making a promotion of Shockli 14500 1000mAh battery from Nov 25th to Dec 3th in our aliexpress store , you can get additional $1 off using the coupon code L8P2H9204M1A.
The products link is as below
https://www.aliexpress.com/item/33029598525.html?spm=5261.promotion_code...
Have a great day.
Best regards.
Shockli Team.
Paul321
Paul321's picture
Thumbs Up , These 14500’s are very good
Paul-
The_Flashaholic
The_Flashaholic's picture
Last seen: 20 hours 19 min ago
Ventsi wrote:
Depends on your taste. I don’t like any of those so I don’t own them. The choice of 14500 lights compared to 18650 is very limited.
The Reylight LAN 14500 is arguably the sexiest light of all time.
My 4K Lumen Whore Reviews (MS18, X70, MS12, DX80, X80-GT, X45vn etc) - http://www.youtube.com/c/FLASHAHOLIC_TV
SKV89
Sexiest 14500/AA light for sure!
Ventsi
Excellent design indeed, however reverse clicky is not my type of switch.
If they make it with an electronic switch and some kind of ramping UI, that would be amazing.
BTW after I wrote this comment I got the ThruNite T10 II and it’s really nice, the only thing missing is a battery level indicator.
Still waiting for the project Sofirn SP10S with Anduril, fingers crossed.
Agro
Agro's picture
Last seen: 5 hours 40 min ago
Sexiest 14500/AA Reylight for sure!
Kevin Z
Last seen: 1 year 8 months ago
I just received some shockli 1000 mah 14500 cells & im getting 30 minutes extra run time with my zebralight H52 headlamp on H1 compared to Pkcell 14500 750mah, fenix 14500 800mah & AW 14500 750mah ,
That’s on first charge from new before any cycles , looks like very good cells.
Mike89
Last seen: 6 months 1 week ago
Amazon is out of these
Ventsi
Shockli-Simon wrote:
Shockli 14500 1000mAh…
Hi Simon, any chance you’re gonna start shipping these to Bulgaria?
Mike89
Anyone know how many amps the Lumintop GT Micro and Lumintop Tool AA pull? Is 3 amps on these batteries enough for those two lights or do I need the Vapcell 650mah 7 amp batteries for those?
andrx
andrx's picture
Last seen: 5 hours 26 min ago
tool aa 2.5 amps with these batteries
hank
hank's picture
Last seen: 4 days 4 hours ago
Do they make any AAA-sized cells?
d_t_a
Last seen: 56 min 30 sec ago
Using a Shockli 14500 660mAh at around 4.00v (ie. not yet fully-charged), I measure around 2.5 Amps on a Tool AA 2.0 with XPL-HD LED, and around 3.0 Amps on a Tool AA 2.0 with XP-L2 LED. I’m measuring around 4.0 Amps on a GT Micro.
maba
Last seen: 1 day 8 hours ago
Hmm, new version 5A vs old 3A Shocked
SKV89
Interesting. The 3A version does higher than 3A if you look at HKJ’s graph. It was rated way too conservatively so I’m guessing it is the same cell with a new wrap.
amtaham
amtaham's picture
Last seen: 14 hours 26 min ago
Another review well done. Thanks, HKJ.
“Come again, please, come again, Whoever you are. Religious, infidel, heretic or pagan. Even if you promised a hundred times, And, a hundred times you broke your promise, This door is not the door of hopelessness and frustration. This door is open for everybody. Come, come as you are.” ~ Mawlana Jalaludin Rumi
Light Veteran
Last seen: 18 hours 5 min ago
They are good for Lumintop Tool 2.0?
I have to use protected?
Flashlight addicted
ArtieT59
ArtieT59's picture
Last seen: 6 hours 17 min ago
It’s nice to see this great review as these were the first 14500 cell I bought. Best ones I have, still using them often 8 months later. Got them on amazon without knowing this review existed(feb 2020) Good price too.
They work great in my thrunite T10 II
I bet they’d work well in lumintop tool.
[FLF] Five Light Friday https://budgetlightforum.com/node/78749
Check out some of my new lights (picture heavy) and quick first impressions of them here: https://budgetlightforum.com/node/77180
My Sft40 beamshots / comparison thread: https://budgetlightforum.com/node/78100
Light Veteran
Thank you
Flashlight addicted
ggf31416
Last seen: 8 hours 10 min ago
The boost driver means that AA flashlights without proper LVP can easily overdischarge 14500s to 0.x V. I lost several Efest to overdischarge in several flashlights, fortunately I haven’t lost any of the Shockli yet. I don’t know whether the Lumintop has good LVP.
Light Veteran
mmm…I don’t know
Flashlight addicted
Grigio
Grigio's picture
Last seen: 1 day 14 hours ago
Light Veteran wrote:
They are good for Lumintop Tool 2.0? I have to use protected?
I still use these bateries for my Lumintop Tool 2.0, for maybe 15 minutes a day, various modes and no problems at all.
