How “convenient” is that for you don't know, but one thing I can say for sure is that such estimation is inaccurate.
As JamesB says, depending on the mind patterns which define each battery (chemistry, construction and etc.) its voltage to capacity and energy curves vary. Therefore, for a device to optimally predict or know the actual battery SoC it must be designed with some specific battery in mind. Otherwise its accuracy will on average be acceptable at most. For example I have built lots of DIY powerbanks with different sorts of cells, and I can tell you their SoC percentage meter very often @#$%.
You can also use Henrik's cell database to check out hundreds of different battery discharge curves.
I know about different curves because of quality, age etc. Ansmann also shows only 6 stages on charge (0-20-40-60-80-100%). It’s not about accurate values but approximation.
Does anybody know why a single slot, in this case slot 3, will not read internal battery resistance? This MC3000 is brand new. Manufactured this year, bought from 18650batterystore, dual fans, newest firmware and I just got it a couple weeks ago.
Everything else about this charger is fabulous except this one slot does not display internal battery resistance. Either on the unit or in the app. Slot 3 seems to function normally in every other way. Tried multiple oem liion cells that the other slots display IR with fine.
Thank you sir. I'm not qualified to chase something like that down and whether I could solder it or not would depend on where it is.
Get this though. I restarted it and the slot is reading the internal battery resistance now That's not a very encouraging sign, but maybe just a software glitch or something.
A quick update on this. It appears that sometimes I wasn't waiting long enough for the analysis to finish and or not getting a 21700 battery seated in the slot cleanly/quickly enough and the unit wasn't able to properly read the resistance.
Hi, I need help, I have a MC3000 for a few years and channels 1 and 2 have stopped working, not even detecting the battery when inserting it. Is it a known bug? Is there a solution?
I have 25 AAA Eneloops of varying age and most test under 100 milliohm, but three test above 200 using a 750mA (1C) discharge. Not a huge concern as I don’t use these in high-drain situations. Still, I’d like to play around with my MC3000’s cycling functions to see if I can improve these batteries.
Is there a recommended program for this? I don’t mind if it stresses or even risks further damage to the batteries as this is mostly to satisfy my own curiosity.
So I just bought one of these a week ago and am trying to learn to use it (I overbought for my needs and level of knowledge) Right now I’m just using it to charge Samsun R25 batteries for my vape mod but I plan to expand to using more rechargeable batteries around the house. I’m trying to create a refresh program for the samsung R25s. Can anyone tell me what the setting would be and how to figured it out so I can create my own programs without having to take up other people time every time I get a new kind of battery. Any help would be appreciated and thank you in advance.
You generally don’t refresh 25Rs or any other Li-Ion battery, there’s no point. Do you mean you want a charge program tailored for the 25R? If you’re thinking about NiMH (like enloop) batteries, the default “Eneloop Refresh Std AA” (or AAA) programs look fine to me. I did a little research since my last comment
So I put those numbers into a program exactly as those specs recommend:
BATT TYPE: LiIon
MODE: Charge
CAPACITY: 3200mAh
C.CURRENT: 1.25A
D.CURRENT: OFF
C.RESTING: 0min
D.RESTING: OFF
CYCLE COUNT: OFF
CYCLE MODE: OFF
TARGET VOLT: 4.20V
TERMINATION: 0.10A
RESTART VOLT: OFF
D.REDUCE: OFF
CUT VOLT: OFF
CUT TEMP: 45C
CUT TIME: 240min
Note “CAPACITY” is a safety number a bit above your actual capacity, in case you were wondering. CUT TIME is also a safety maximum above how long it should actually take.
You could change these (or add a second program) for faster, still safe, within specs, and get you like 90 to 95% charge in about half the time:
C.CURRENT: 2.5A
TERMINATION: 0.25A
CUT TIME: 180min
If you have other 18650s and you’re not sure what to use, these will be slow, but safe:
CAPACITY: 4000mAh
C.CURRENT: 0.75A
TERMINATION: 0.10A
CUT TIME: 360min
The point of a tailor made recharge program is to get full use of your battery so it runs the longest every day and performs well over hopefully several years, while charging safely and quickly. It’s a balance between these factors. Honestly any decent charger will be fine in 99% of cases but the MC3000 allows you to tweak things.
There is no point to refresh LiIon cells. You can run C>D cycle as per manufacturer recommendations (charge current, end of charge current, discharge current, end of discharge voltage), only to measure discharged capacity. This may be useful if you want to follow the state of wear of your cells. If you have a reference on the new cell, you may want to do it once every 30-40 cycles.
As mentioned here, here are some links to MC3000-specific info I posted on another thread. I’m reposting here to try and make it easier to find as this seems to be the BLF’s “main thread” for the MC3000:
Initial discussion about firmware versions for the MC3000, specially v1.15 vs v1.18 (will be continued here): Checking mAh - #58 by dmenezes (and the next 4 posts following it).
Following up on this, early this morning I managed to get ahold of a helpful representative at the SkyRC website chat, and asked about v1.17 (which came on my SkyRC MC3000, purchased late last April), the previous version v1.15, and the current one v1.18;
TL;DR: v1.17 has a bug (related to the operation of D.REDUCE setting and possibly to its “inverse similar during CV-Phase of Li-Ion battery charging”[1] which is why SkyRC does not make that version available for download, and instead recommend updating to v1.18. I asked about falling back to 1.15 in case 1.18 doesn’t work for me, but they apparently evaded that question.
[1] see the SkyRC manual p.22, under “D.REDUCE”.
And here’s the complete transcript (edited for clarity/brevity):
13 Sep, 2023
[15:08] DMenezes: I have an SkyRC MC3000 with firmware 1.17. I see there’s an update available for firmware 1.18, but I’m worried that the new firmware could not work as well and I would need to go back to the old one.
[15:09] DMenezes: I searched the SkyRC website for version 1.17 so I could go back to it if needed, but could but could not find it. I could find version 1.15, tho.
[15:11] DMenezes: My question is, is there a reason the older version (1.15) is available for download, but the newer one (1.17) isn’t?
[17:34] SkyRC: There is a bug in V1.17
[17:34] SkyRC: So we did not put it on the site
[17:35] SkyRC: The bug is about the charge or discharge reduce
[17:50] DMenezes: Ok, so I better upgrade ASAP, I guess
[18:34] DMenezes: if I upgrade to 1.18 and it doesn’t work for me, should I then move to 1.15?
Yes, the person did not answer the firmware rollback question… I swear I read that it was possible. Probably in that CPF thread where people were dealing with Betas.
Too bad he didn’t point you to a changelog. But at least we know why 1.17 is not available.
I will try and ‘update’ (actually, fall back) to 1.15 first (and run with it minimally, in order to answer that question), and then to 1.18 (and use it extensively, to see how well that version works). Will post my results here.
Might take a while (from many hours to a couple of days) as I’m currently recovering from a data-loss event on my computer, and have to finish it before rebooting into Windows to do these upgrades.
