Throw xhp35 hi > 3v xhp50.2 > xhp70.2
Lumens goes the opposite way. Probably along with battery drain if that matters to you.
xhp70.2 is a beast, expect it to be big and bright but not carry as far.
Xhp35 is the only de-domed one which makes it throw better (+ the fact that its smaller and that generally = more candela) the 4000k is super pleasant of you’re into warmer (possibly higher CRI) tints. It’s also discontinued, what ever that means in this hobby anyway:P
I just would like to ask, if you have access to either XHP35 HI or the new XHP35.2 HI (introduced in March 2020) emitters.
Basically, the XHP35.2 HI has very similar performance stats to the older XHP35 HI, but I think, at some time point, XHP35 HI will be more difficult to access, and XHP35.2 will be better available.
The most important question is, can you get 90 CRI tints of either the old XHP35 HI, or the new XHP35.2 HI, and if so, what CCTs you can access at your Cree retailer?
These 2 made me smiling for days. M21B is perfect host for XHP50.2 and new T2 is simply WOW.
Although description of new T2 say it’s 0.5A on AA and 1.5A on Liion, when running both chemistry on max setting, brightness difference is minimum. At least to me.
I just love it. Perfect size and bright as hell.
Simon
You consider to do an AAA light with E21A 2000K?
Because this CCT does not harm the endocrine system and the sleep cycle,
and is perfect for indoor use.
We lack them.
