I also had some trouble taking the Tronic Ni-MH cells (from Lidl) from some of the last C01 and even the C01S I recently bought. I will give them away with alkalines inside, but it is a bummer to have these differences between samples
Yes, AA/A Lidl cell are larger,but the Ikea (white) fits well and are great cells.
1 year and are still full charge and their capacity is real with good discharge
A pack of 4 cost almost one C01,what a steal!
Because indoors itās the only light, and outdoors there are other lights that may disturb your view.
Chance that you are in ānight visionā mode is higher than when you just stepped out of your car.
Or: distances indoors are smaller than outdoors (my front yard is bigger than my bedroom)
indoor distances are shorter than some outdoor distances
something at arms reach,
a plate of food while seated at a table,
does not need a lot of lumensā¦
no matter indoor or outdoorā¦ the key is the distance you want to illuminate
the door handle to the toilet indoorsā¦ the zipper pull on a tent door outdoorsā¦ the keyhole on the car doorā¦ all these things are within hands reachā¦ so the same lumens sufficeā¦ no matter indoor or outā¦ its all about the distance
The C01 is a 7 lumen light. As a rule of thumb thats good for distances of 7 feet or less.
Yes and no. Itās not a ābareā LED with silicone coating or dome. Itās a 5 mm LED with hard plastic housing, sitting in an aluminum āreflectorā.
correct, that is normal, no glass lens needed nor available.
the 5mm LED is manufactured with a waterproof optical dome, and installed with an O ring around the base. No water or dirt can get into the electronics.
if you had ever seen a Fenix E01 (which cost more and was not High CRI), it had the same no glass lens. It is a very durable design.
Thanks Jon and Sammy! I was surprised that there is no glass lense but I donāt think sofirn will forgot the lense there must be something Iām missing. Lol
This is the first kind of light I have with this design. Very interesting.
