Thanks for the comments. Wife and daughter are well
Also, for some reason my brain wants me to put a warm LED in a brass light. It just feels right. To that end, I’ve reflowed one of my 3000K Luxeon HL2X 80+ CRI on a 16mm copper MCPCB. I thought I had a 219B warmer than 4000K but I don’t, so I’m using this.
The current challenges I’m looking at: The MCPCB floats. I devised a way to improvise a “shelf” using a part of the 3/4” x 1/4” “hose swivel adapter”, but that still leaves me with a few millimeters between where the MCPCB rests and the height it needs to hit for the LED to be sitting in the TIR. (Determined with my digital micrometer.) My best guess for how to do this is going to be a few brass washers stacked together to get the extra height. I also need to figure out how to mount the driver, and get it grounded to the body. I think if I can figure out the shelf to the MCPCB, I can use E6000 to hopefully glue the driver to the underside of that, but I’d still need to ground it since it doesn’t really get anywhere near the body tube. Worst case I can probably try to solder a wire from the ground ring of the driver to the body somewhere, or solder some sort of spring (or a cut fragment of a spring, or a few of them!) onto the edge of the driver to make contact with the tube.
Another of my concerns with the assembly methods discussed above is the practicality of the light. It’s already going to be quite heavy so it’s never going to make EDC duty, but I really don’t want half the head assembly to come sliding out of the dang thing every time I go to swap the batteries. I’m going to be keeping this in mind as I go. If at least one part of the stack is captive in the head assembly, and the rest is all adhered to that piece (soldered, glued, whatever - I’ll take it), it will be good to go.
P.S. I just realized if I E6000 the driver to the “shelf”, it will technically be potted…
Edit: Adding a pic to attempt to show the height issue in the head. The “lip” that’s closer to the camera than the MCPCB is where the improvised shelf would rest. I also measured the gap, it’s about 3.6mm
So it occurred to my that it might be possible to cut one of those 3/4” x 1/4” “hose swivel adapter” pieces to fit. The plan is to cut if off with about 3.6mm (it’s okay if it’s a little longer, but not much shorter) past the “shelf” part. The narrower end would end up attached (soldered?) to the MCPCB, and the wider end would get the the driver attached to it. I would probably have to cut and/or file some notches for the LED wires to route through the center-hole to the driver. We’ll see how the part comes out first - I’m planning to start the cut with a hacksaw to guide the hacksaw-blade on my reciprocating saw.
Edit: I did it, this is gonna work! Pics to follow.
The start of the cut:
The finished cuts, plus some minor sanding:
My improvised clamp since I don’t own a vice… (bargain bin Tractor Supply Co vice grips that were a three-pack for $3 and one of my clamps):
The fit will work!
Now to see if soldering will work…
Here goes nothing.
I added a ground strap (green 30 gauge wire) from the driver to the driver-shelf. Tough to solder to that driver-shelf...
Next I carefully test-assembled everything, including sticking a bullseye-shaped sticker sandwiched between the driver and the driver-shelf to prevent shorts.
It's alive!
Now I've got the E6000 between the driver and the driver-shelf, and I'm hoping that sticks. If it does, the build will be completed tomorrow when I assemble.
One thing I will say for this build is that it ended up being a bit short for an 18650. It was tough threading the tailcap onto the body tube with the head fully threaded on, and I couldn't tighten it much, and I'm already using an unprotected flat-top battery. This would probably work best with something like 18500. (I checked, my 18350 is way too short!) Given that the light is already longer than my D4, and how short I got certain elements of the light (the switch assembly protrudes out the tailcap and the stack for MCPCB/shelf/driver is quite thin by my standards), it gives me a lot of respect for short lights!
Also, I don't have a _ton_ of faith in the heat path for this light. In fact I debated ripping out half the 7135s. If I had more faith in my ability to do it without ruining something, I'd likely try to solder the shelf to the body tube. But I don't think that's within my abilities.
Yahoo it works ! That soldering to big stuff , like the body keeps alluding me . I have even tryed preheating but haven’t gotten very good results . I’ve seen others do it , so I know it can be done . Nice improvising to get it done .
I think the trick is probably preheating + hot air, lots of flux, and appropriate materials. For example I doubt I’d ever bother trying to solder to an aluminum host/shelf because aluminum is very difficult to solder to. Brass/copper can be done though!
I found trying it with regular solder on brass was a nightmare, however that ‘Mechanic’ solder paste from ali express seems to work every time, first time with no prep or pre heating.
I don’t know if it kinda ‘etches’ the surface, but it worked for me really easily. This was the first time I’d ever used it and I have to say I’m wondering where it was all my life - it is SO useful.
So, a progress update. Good news and really bad news. The good news is the E6000 holds to the brass, at least well enough after less than 24 hours that I could test assemble the light.
The bad news is, I let the smoke out of it. I need to replace the driver, and I don’t have a lot of good options available. Looks like I’m rummaging through the parts bin.
Edit: Update: Nothing in the parts bin. I’m going to have to steal a 17mm 8x7135 driver from my VG-10S.
Swapped the driver and did some test connections. It works - though it’s apparently a bone stock Convoy 3-mode driver. Complete with NMM if you treat it wrong and an annoying whine on the medium mode. To hopefully not let the smoke out of this one, I’ve gone ahead and potted the entire top-side with liquid electrical tape. Once that cures I’ll apply the E6000 to glue it to the driver-shelf.
I forgot to add, the E6000 was, after not-quite-24-hours, sticky and stretchy but I was able to pry it off everything with a small flathead screwdriver and significant effort.
Due to internet issues, I finished this last night but am working on getting things posted. All I did was add the ground strap from driver to shelf and it worked fine.
