About the fan parallel to the leds: since with leds the voltage is not lineair with the output (voltage difference from very low to turbo is fairly low) and cooling power of a fan may be much closer to lineair with the voltage, it is not optimal, but at least better than having the fan at constant speed.
Cool project! I’ll be following this one. In my fan cooled lights I run the fan at a constant speed and call it good. I set the fan speed with appropriate resistors and use a fan rated at close to the led voltage (5v or 12v).
The project is progressing pretty good. I tested 5 reflectors and decided to go with the 73mm from kaidomain.(ordered 4 of them). I managed to focus it really good on my sbt90.2. (3 more one their way from Hank). Delays in delivery are unfortunately unavoidable so I am concentrated on the heatsink for now.
I have drilled the 280holes (2.9mm) in the 6mm copper disc and will later add the 3mm thick copper pins. These will vary in length from 46mm to 16mm depending on the space avaliable in the head.
Question I was thinking and researching a little about how to increase the surface area of my pins. I came up with the idea to cut threads to each of the copper pins that will run their whole length. I found some rough calculations that a screw has around 50-65% and maybe up to 100% more surface area than the same diameter cylinder/rod. This sounds pretty amazing to me.
What do you think about that? Will the threads possibly improve cooling? The airflow will be parallel to the pins and perpenducular to the threads. My main concern is to not make things worse, because the airflow will be perpendicular and wont hit directly the valleys of the threads. Any other ideas to increase the surface area?
The heatsink is finally ready, here are some photos of it
It weighs 907gr/1.99lbs and has and an actively cooled surface area of aproximately 720cm2/111square inches. This is only the copper, didnt include the head of the flashlight.
(If I remeber corectly) it has 278, 3mm copper pins that reach through the 6mm thick copper to the leds. It took ages to drill all the holes and press fit/hammer all the pins but I had enough time during the holidays and enjoyed it. The other side doesnt look so nice for now as some pins are longer and some shorter, it needs some more work…
I managed to calculate the surface area of a BLF GT94 from pictures and found out that it has around 1450cm2 of fins and probably some more surface area if you take into account the rest of the head. This is twice as much as my heatsink but it is not actively cooled. The heatpath is also shorter with my heatsink. Honestly I have no idea what is better and from which point is a passively cooled heatsink equal to an actively coolled one. Material wise copper is better than aluminium, but I dont know if I managed to build somehing superior to the the GT94. probably yes. (But also extremely inpractical due to the weight).
The battery tube and the contact point to the driver are also ready. I visited the local machining shop again and had the tubes done there. Then JB welder them together. The contact points are just 1mm thick copper sheet and I made them with a dremel, didnt use a lathe for these.
And a small preview. The upper part of the head is missing of course. I am waiting for the reflectors to come.
This is looking great so far. Im looking forward to seeing how well the copper heat sink dissipates the huge amount of heat that will be conducted to it. If anything, it should dramatically increase run times at the higher power levels. Thanks for sharing.
Also screwed onto the head, already some copper patina from the constant handling…
This is the cooling concept and almost final assembly of the head:
I milled out the existing fins using a drill press, a 2mm end mill and a jig to hold the head stable to create the air intake. Then the final work with a small file. Also drilled through the tripod mount at the back side to allow slightly more air flow.
Next step is to cut the 4x 73mm reflectors and epoxy them together. After that I need to make some centering rings for the leds and finally screw them on the heatsink. The speed controller for the fan will be probably at the upper compartment where the reflectors are and not near the driver, because I dont want any extra components near my air intakes obstructing airflow to the pins. The potentiometer for the fan speed controler will be placed at a random location that I will need to figure out and consider comfortable to use. I wanted to use the tripod mount (drill through) as place to put the potentiometer but it seems the least comfortable place, plus I need this hole for extra air flow.
